Dislikes: 0
Junior Member
DIY 1 and 2 inch foam pads
Looking at the price of Flex 1 and 2 inch foam pads,I was wondering if anyone out there has ever cut down one of their pads,(ie. LC CCS pad) and made their own small pads to do intricate work ? With a 1 inch pad being almost as expensive as a 6 inch pad,I thought it would be worth a try.
I cut a circle as best I could out of a LC CCS orange pad,I trimmed off some of the the face of the pad so it wasn't too thick. The pad is very crude looking,and I'm sure there is a better way to cut and shape the pad. I used the P E8 Flex 1" backing pad and Menz. 400,polishing speed set at 2. I scuffed up my old hood with 3000 grit paper and tried it out. You can see the dull scuffed side and the polished side was swirl free. No sun today so the pics don't do justice. I'm sure in a pinch it might work.....
Super Member
Re: DIY 1 and 2 inch foam pads
I haven't but that's a great idea.
Thanks
Reason: Spelling
Super Member
The problem is at the rpm's you will be running at you better be able able to get them perfectly round and balanced. Good luck with that, let us know how it turns out.
2013 Genesis Coupe 3.8 Track Edition
2015 Hyundai Sonata Limited, 2016 Pearl White Nissan Altima SR
2019 Nissan Rogue SL
Junior Member
Here is another pic of the job done. The scuffed side was done with 3000 grit paper. I made 6 section passes with the Flex PE8 on speed 2 setting. For a crudely circle it did a swirl free job. Now to find a way to cut perfect circles,THEN, cut the face of the pad down evenly.......I love a challenge...
Like I said, it was a crude cutting job, but I'll keep you posted when we come up with what we think will work for cutting pads in a perfect circle.
I have an idea as to how you could cut the pad. Get a cookie cutter in the size that you want and just a regular propane torch. Heat the cookie cutter and it "should" make a clean cut.
Better yet, get a piece of steel pipe in the diameter you want,file down the inner or outer edge to make it somewhat sharp,place it over the larger foam pad and hit it with a hammer. Viola,home made pad punch. Just put wood under the foam before punching.
Regular Member
I have done this a year ago. I placed 7" cutting foam Pad on a 3.5" backing plate and used a jigsaw blade to cut the pad perfectly round....(by hand). This works well with my drill for headlights.
Tom
Junior Member
I bet a hole saw would work amazing for this.
Super Member
Nice, there is a better way to cut prob. I've been meaning to get a da adapter/extension rotary for my da, alot of ppl say not to but you only need so much in certain areas.
Super Member
Personally, anything intricate enough to require a 1 or 2 inch pad I'll just do by hand. But then again, I'm not doing this as my everyday job.
Similar Threads
By Mike Phillips in forum Product Reviews by Mike Phillips
Last Post: 03-11-2019, 07:52 AM
By MDMachiavelli in forum Wool & Foam Buffing Pads
Last Post: 12-17-2016, 12:02 PM
By tedj101 in forum Wool & Foam Buffing Pads
Last Post: 05-24-2014, 07:56 AM
By john b in forum Wool & Foam Buffing Pads
Last Post: 09-10-2012, 07:43 PM
By Meghan in forum New Car Care Products
Last Post: 01-08-2008, 08:03 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
