Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    Super Member custmsprty's Avatar
    Join Date
    Apr 2012
    Posts
    7,494
    Post Thanks / Like
    Re: Harbor Freight DA 6" Polisher
    Quote Originally Posted by kevincwelch View Post
    Beautiful.
    Question: Those swirls don't look too bad; why not use a white pad/polishing pad with Adapt? I'm curious if you tried that and then settled on the orange pad or if Adapt tends to work better with a firmer pad.
    Yup, went down that road.
    It's all in a show and shine write up, this may help.
    2014 Nissan 370 Z Griots G21 HD Adapt 7 HD Poxy
    2013 Genesis Coupe 3.8 Track Edition
    2015 Hyundai Sonata Limited, 2016 Pearl White Nissan Altima SR
    2019 Nissan Rogue SL
  2. #22
    Super Member Mike Moore's Avatar
    Join Date
    Dec 2009
    Location
    Sunny South Florida
    Posts
    967
    Post Thanks / Like
    Just a FYI - my favorite DA in the price range is the Griots 6" with the lifetime warranty.
  3. #23
    Super Member kevincwelch's Avatar
    Join Date
    May 2013
    Location
    Oak Park, IL (Chicagoland)
    Posts
    2,686
    Post Thanks / Like
    Quote Originally Posted by custmsprty View Post
    Thanks, man. Nice write up. I will be tackling my annual detail soon and have some HD Adapt to try out... Although I think with the general condition of my paint HD Polish will be enough.
    (Sent from my mobile device.)
    Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
    2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
  4. #24
    Junior Member Capn Blackie's Avatar
    Join Date
    Jun 2014
    Location
    Illinois, South
    Posts
    68
    Post Thanks / Like
    I started with the HF not long after finding these forums because I didn't have the money at the time to get better and really needed something to keep me busy (girlfriend took off).
    I did the various upgrades(longer cord swap, smaller backing plate) and it has done a great job but I am just doing my car and friends and family, not using it consistently.
    It is a good machine but just as the others have said you can do better for not that much more. The GG would have probably been a better by in the long run, as others have said that warranty is really handy.
    I'm just about to step up to the Flex but I'll hang onto the HF for either smaller jobs or working on carpets.
  5. #25
    Super Member Jaretr1's Avatar
    Join Date
    Jan 2011
    Location
    Miami
    Posts
    2,391
    Post Thanks / Like
    If you havent already purchased HDSpeed, might also want to consider Mckee's 37 360 AIO. It is the easiest AIO to use as it literally disappears as you work it.
  6. #26
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,728
    Post Thanks / Like
    Quote Originally Posted by Mike Moore View Post
    agreed and it can be bought here at AG which helps supports GG as well...
    i am the jump starter.
  7. #27
    Super Member
    Join Date
    Feb 2013
    Location
    Just south of the Mason/Dixon line
    Posts
    256
    Post Thanks / Like
    Quote Originally Posted by Jaretr1 View Post
    I highly agree. There is a difference between the PC and Harbor Freight tool. For one, the HF tool is at least a pound heavier than the PC, which may not seem like much, but when using a tool with a lot of vibration that is almost 15-20% heavier, it adds up. Its LOUD! Its also not smooth, lots of vibration. The PC is a far superior tool. Even if you use it just a few times, its worth spending the extra money.
    I have both the PC & HF and cannot tell the difference in them as far a vibration or sound goes.
    But I did swap out the factory grease on the HF and did not on the PC.
    The HF does not bog down as easy as the PC does on curved panels.
  8. #28
    Super Member
    Join Date
    Feb 2013
    Location
    Posts
    256
    Post Thanks / Like
    Quote Originally Posted by yamaharider529 View Post
    Hey guys I'm looking at getting this polisher just to do my vehicles with and see most people are saying to get a 5" backing plate. My question is will any 5" hook and loop work? Also I seen some people saying to get a counterweight for the 5" plate instead of using the one it comes with. Just wondering if any brand both of these will work. Thanks
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Go over to the sister site ACC. They have the open box specials and GREAT prices:
    Open Box Polisher April Batch #1
  9. #29
    Regular Member kaliagent2001's Avatar
    Join Date
    Mar 2016
    Posts
    126
    Post Thanks / Like
    After working with a rotary for 10 years i bought my DA from HF and i will never buy one again. Didnt last long, didnt correct well and it vibrated like no tomorrow. Spend the extra 50 and get a porter.
  10. #30
    Newbie Member Steelholder's Avatar
    Join Date
    Apr 2016
    Posts
    28
    Post Thanks / Like
    I bought a used hf this weekend for 20$. It worked great for wax application.I've only used a da once before this was my second time. For wax application it was AMAZING, cut my time down significantly compared to waxibg by hand.
    Like others have mentioned, replace with 5in BP, add grease to gears,(very easy YouTube diy), rotate body so that on off switch is facing up and not to the left.
    The previous owner added grease and it ran strong when I cranked it hopefully it lasts. If you're looking to buy a new one I'd say go for it , get the warranty for peace of mind, if it lasts you a year it'll probably run for a good while. There are three different variations of the HF 6in polisher the newest one is 62862.This version seems to address the previous BP problems it had but get an aftermarket 5in BP anyway(id go with Meguiars)
Similar Threads
  1. Harbor Freight DA polisher N/A. Alternatives?
    By SoreArms in forum Auto Detailing 101
    Last Post: 05-28-2019, 08:53 PM
  2. Harbor Freight Polisher
    By DaneMcWilliams in forum Auto Detailing Tools and Accessories
    Last Post: 08-14-2018, 03:27 PM
  3. Harbor Freight polisher question
    By Supergus1 in forum Ask your detailing questions!
    Last Post: 12-04-2014, 08:04 PM
  4. Harbor freight 6'' da polisher pad question
    By jstevens66 in forum Auto Detailing Tools and Accessories
    Last Post: 05-09-2014, 03:39 PM
  5. Harbor Freight DA Polisher - New
    By Viper6 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 11-30-2013, 11:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
