Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
  1. #1
    Senior Member
    Join Date
    Mar 2010
    Location
    Mauritius
    Posts
    352
    Post Thanks / Like
    Operation Clear View - wiper marks & swirl removal from glass
    Hi folks
    Been inactive for long,
    Anyway, presenting to you 2 cases in one:
    1. Persisting with wiper blades that are long past their prime
    2. Using amateur techniques to remedy damage caused by bad wiper blades that have actually worsened the driver`s line of vision
    Torn wiper blades or wipers missing the rubber blade edge can often leave deep scratches along with streaks on your windshield. These scratches will be just as distracting as streaks. They will reflect sunlight and headlight beams from oncoming traffic. Scratches will definitely obstruct vision, making driving more dangerous. However, it is important to remember that damage can occur any time a repair is not done correctly, making vision still more obstructed.
    Tools & Products
    - local APC & towels
    - Sonax clay
    - Sonax felt pad
    - Sonax glass polish
    - Makita rotary
    - A spray bottle with water
    - Menzerna Powerlock sealant and applicator
    Process
    - wash and clay the glass
    - tape all rubber trims and cover adjacent areas
    - mist the felt pad with water
    - apply the polish to a small section of the glass
    - proceed slowly to prevent heat build-up. every now and then, spray water on the surface being polished
    - check your work at all times, it may require quite a few hits
    - be patient and check the temp regularly
    - clean and apply a sealant, let cure and wipe
    Letting the pics speak:
    Front glass: water spotting and swirls
    water spots removal gone from bad to worse
    swirled glass
    close-up of damage caused
    can u see through?
    The result of using inappropriate products, tools and techniques to remove wiper scratches
    From inside.....clarity or a lack of?
    closer
    Worse still, during a rainy day or night when facing headlight beams from oncoming vehicles
    Close-up: wiper scratches have been left intact while new scratches have been instilled
    Rear glass: heavy water spotting from acid rain/ wrong maintenance
    Close-up
    TA DA
    Sealing the whole work
    Sealing for a wiper free drive
    Wiping after curing, we`re grateful to Almighty, all scratches gone and clarity restored
    Mirror, Mirror! Where are the water spots
    Can you see through?
    Thanks for viewing. Your thoughts and questions are most welcome
    Zaid
  2. #2
    Junior Member
    Join Date
    Aug 2017
    Posts
    1
    Post Thanks / Like
    Re: Operation Clear View - wiper marks & swirl removal from glass
    Nice work! How much time do you estimate it took you to get those results?
  3. #3
    Senior Member Route246's Avatar
    Join Date
    Mar 2017
    Posts
    495
    Post Thanks / Like
    So the polish took out the wiper scratches? Is that what took multiple passes?
  4. #4
    Senior Member
    Join Date
    Mar 2010
    Location
    Mauritius
    Posts
    352
    Post Thanks / Like
    Quote Originally Posted by mperfct View Post
    thanks mate. The whole process took approximately 4 hours.
    You have to proceed gently and slowly because of the heat build-up
  5. #5
    Senior Member
    Join Date
    Mar 2010
    Location
    Mauritius
    Posts
    352
    Post Thanks / Like
    Quote Originally Posted by Route246 View Post
    it's a combination of polish, the felt, the action of the rotary (around 1400-1500 rpm) and the pressure applied. yes
  6. #6
    Senior Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    10,747
    Post Thanks / Like
    Do you know if the Sonax Glass Polish contains cerium oxide? BTW nice job.
  7. #7
    Senior Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    18,307
    Post Thanks / Like
    Quote Originally Posted by Rsurfer View Post
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
  8. #8
    Join Date
    Jan 2007
    Posts
    10,747
    Post Thanks / Like
    Quote Originally Posted by FUNX650 View Post
    Is that an abbreviation for cerium oxide?
  9. #9
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    18,307
    Post Thanks / Like
    No...not an abbreviation;
    looks more like a translation:
    ~Joaquin de Setanti
Similar Threads
  1. Removing wiper marks from a windshield
    By Calendyr in forum Tricks, Tips and Techniques
    Last Post: 07-27-2017, 05:41 PM
  2. Replies: 0
    Last Post: 07-23-2017, 12:41 PM
  3. How to resolve wiper wear marks on windshield?
    By eyost in forum Auto Detailing 101
    Last Post: 11-07-2012, 02:28 PM
  4. Masking a Clear Bra for Polishing (Swirl Removal)
    By BentShaft in forum Ask Mike Phillips your detailing questions!
    Last Post: 01-29-2011, 11:04 AM
  5. 3M Clear Bra swirl marks removal suggestions?
    By darius_latamus in forum Auto Detailing 101
    Last Post: 04-30-2009, 02:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» October 2017
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
