Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    Senior Member dlc95's Avatar
    Join Date
    May 2013
    Location
    Rochester Hills, Mi
    Posts
    4,008
    Post Thanks / Like
    Rupes Mini And The Missing Anti-Spin Shroud
    This has been nagging at me since I got the Mini.
    First thing I noticed is that the infamous Anti-Spin shroud is absent from this tool. Is backplate speed limited by the smaller diameter of the back plate, or some other factor?
    That tool rips through defects very quickly. I can't help but wonder if the missing shroud is a factor.
  2. #2
    Junior Member
    Join Date
    Nov 2016
    Posts
    14
    Post Thanks / Like
    Re: Rupes Mini And The Missing Anti-Spin Shroud
    Hi the Rupes mini does not have an anti-spin shroud
  3. #3
    Senior Member
    Join Date
    Sep 2017
    Posts
    186
    Post Thanks / Like
    Maximum backing plate speed isn’t dictated by the shroud especially when the pad is on the paint surface. The shroud is a safety mechanism for inexperienced users who lift the polisher off the paint surface while its powered on. The reason why the Mini has ridiculous correction is with its ability to rotate so well as the mass and size of the pad is basically half that of a regular DA coupled to the fact that it slingshots 12mm across the paint. Oh and theres the little thing about the polishing action being concentrated over a small 3-4” surface making correction phenomenal.
  4. #4
    Join Date
    May 2013
    Location
    Rochester Hills, Mi
    Posts
    4,008
    Post Thanks / Like
    Over the summer, I attended a Rupes training class, with Todd, Dylan, and Chip.
    I posed this question to Todd, and Chip. Their response was that it was the overall size of the tool. Simply, it was too small.
  5. #5
    Senior Member
    Join Date
    Jul 2017
    Location
    RI
    Posts
    170
    Post Thanks / Like
    I would imagine it has something to do with the pad size as well. 3" machines in general are easier to stall because the pressure is distributed over a smaller footprint. You wouldn't want to slow rotation to begin with, then any pressure would completely stop it.
Similar Threads
  1. Recommended pads for Rupes mark ll and Rupes mini
    By Elger in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 09:32 AM
  2. Replies: 29
    Last Post: 05-21-2016, 07:46 AM
  3. Rupes Shroud Grease
    By dlc95 in forum Ask Mike Phillips your detailing questions!
    Last Post: 08-03-2015, 11:19 AM
  4. Rupes Mini 12 vs Griot's Garage Mini Polisher
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 11-13-2013, 12:57 PM
  5. New Rupes Duetto and Rupes Mini Polishers vs Prototypes
    Last Post: 11-13-2013, 08:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» December 2017
2627282930 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
