Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    2014 Audi A7 Prestige only deserves 'the Finest'
    This gorgeous luxury sedan was brought to me for a thorough cleaning, inside and out, as well as our premium CQuartz Finest paint coating for years of durable protection, amazing gloss, and ease of maintenance. We started with a lengthy wash and decontamination process, the paint was the spot corrected to remove some scratches, and then the vehicle was thoroughly polished to a very high gloss. The surface was cleaned again and was then coated with the ceramic coating. The interior was thoroughly vacuumed, all vinyl was protected, and the leather was steam cleaned and then conditioned. The engine was also pampered and looks brand new now. Audi truly captured the definition of luxury with this car... it was a lot of fun working on it for the past few days. It turned out amazing!
    Process
    Exterior
    Tires: Tuf Shine Tire Cleaner & Tire Brush (repeated 7-8 times per tire)
    Wheels: Sonax Full Effect, Iron X, Tarminator agitated with various tools and brushes
    Foam Pre-Soak: CarPro IronX Snow Foam via DI Foam Lance & Karcher X-Series Pressure Washer
    Wash: CarPro IronX Snow Foam (2 bucket method)
    Misc. Cleaning (emblems, grills, etc): Meguiar's D103 (10:1) and 1.25" Soft Boar's Hair Brush
    Iron/Fallout Removal: CarPro Iron X
    Bug & Tar Removal: Tarminator
    Decontamination: NanoSkin Fine Grade Mitt with Glide as Lube
    Taped off trim and other areas of concern
    Paint Thickness Readings Taken
    Compound: HD Cut on MF pad via Rupes LHR21es and LHR75e
    Polish: HD Polish on Crimson LC Pad via Porter Cable 7424XP and Griot's Garage DA
    Polish & Oil Remover: CarPro Eraser
    Ceramic Paint Coating: CarPro CQuartz Finest (2 thick coats)
    Glass: Polished with Ceriglass and sealed with CarPro Reload
    Wheel Protection: CarPro HydrO2
    Tire Dressing: Optimum Opti-Bond Tire Gel
    Trim: CarPro DLUX
    Exhaust Tips: CG Metal Polish + Protection by hand using #0000 steel wool on heavy buildup and a MF towel for the remaining light buildup and oxidation
    Interior
    Blow out cracks and Crevices w/ Master Blaster Sidekick
    Thorough vacuum of all seats and carpets
    Dusted Dash and Trim
    Vinyl cleaned and protected with 303
    Leather Cleaning: Steam cleaned
    Leather Conditioner: Griot's Garage Leather Care
    Glass: Meguiar's D120 with DI Glass Towels
    Odor Removal/Air Freshener: Meguiar's Whole Car Re-Fresher Odor Eliminator Mist
    All weather floor mats: Scrubbed with D103, rinsed, and blown dry
    Engine
    Rinse
    Scrubbed with D103 and various brushes
    Blown Dry
    Plastic dressed and protected with 303 aerospace
    Hoses dressed with CG Black on Black
    Underside of hood wiped down with UWW+
    ... I know I am forgetting some steps, but you get the idea
    Total time: ~19 hours
    Before
    The exterior was dirty leaving the paint looking very muted and dull
    A car this size needs large brakes to slow it down... this typically means there is a lot of brake dust, and these wheels were covered in it.
    The barrels of the wheels appeared to have never been cleaned as they were far dirtier than the faces of the wheels.
    Buildup on the exhaust tips
    During
    As always, I began by cleaning the tires. These tires had an excessive amount of dirt and tire dressing buildup on them. Each tire was sprayed with tire cleaner, scrubbed, and rinsed a total of 7-8 times until they were clean. I used an entire bottle of tire cleaner on these, but it was worth it. (note the warning printed on the tire... kind of funny... haven't seen that before)
    Still working on the tires... getting cleaner.
    Once the tires were clean, I turned my attention to the wheels. The wheels were sprayed with a liberal amount of wheel cleaner to help loosen the dirt and grime.
    This wheel cleaner changes to a bright purple color as it reacts with iron particles (such as brake dust). You can that the wheels were covered with contamination.
    There was an impressive amount of filth being washed away from these wheels.
    The wheels looked MUCH better after they were cleaned.
    The wheels were sealed with HydrO2 to provide additional gloss and protection for the next month or two.
    The barrels were also cleaned and sealed, of course.
    Next, the grills, emblems, and other smaller areas were thoroughly cleaned with a soft boars hair brush to loosen all of the dirt that collects in these honeycomb designs.
    The vehicle was then foamed with a heavy concentration of degreasing shampoo to loosen the heavy dirt buildup and also eliminate any remaining wax or sealant (though the paint appeared to have no protection on it). The vehicle was then rinsed and hand washed.
    After the wash process, the vehicle was decontaminated to remove any iron particles, tar buildup, and other bonded contamination. The paint was then polished to near perfection. This vehicle was in pretty good shape from the start, and the highly metallic paint color made it very difficult to capture defects, therefore I did not take the time to try to capture before/after type shots for this project.
    Matt working on the final finishing polish... check out those reflections!
    The large B-Pillars were in need of some attention. Unfortunately these jet black pillars are painted with some incredibly soft paint and are very easy to scratch/mar.
    Pillar before correction
    After a 2 step correction
    Retired Professional Detailer
    Sep 2012
    St. Louis, MO
    3,443
    Re: 2014 Audi A7 Prestige only deserves 'the Finest'
    Once the vehicle was polished and the paint was prepped, 2 thick coats of CQuartz Finest were applied to the paint. This enhanced the gloss even further, and the shine was absolutely incredible. The coating was then left to 'bake' in the sun for several hours, and then put away for the evening.
    The tires were dressed with a premium water based dressing to nourish the rubber and leave a nice, black looking finish.
    The exhaust tips cleaned up some during the wash process, but there was still a fair amount of baked on carbon buildup and some light oxidation on the metal.
    The tips were polished and sealed. They looked as good as new.
    The interior was blown out, vacuumed, dressed, leather was steamed and conditioned, and then the vehicle was treated with an odor removal product to attempt to eliminate a faint smoke smell.
    After
    The engine was washed, degreased, blown dry, and then dressed/protected. The engine bay looked brand new
    Wheels and tires cleaned up nicely.
    The car looked incredible
    The paint looked great in the sun... it was nearly flawless.
    This metallic grey looked great out in the sun!
    This car was packed with features... check out the retractable spoiler.
    This car looked better than new!
    I had a good time working on this car, and was very pleased with the results! I could have taken tons more pictures of the finished product... this car was gorgeous in every way. Well done Audi.
    As always, thanks for reading!
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    Amazing work and photos, Zach!!! You do stellar work.
    Super Member sproketser's Avatar
    Aug 2012
    Qc . Canada
    2,660
    Wow , much needed love on the Audi !
    Great pix .
    May 2014
    79
    I love the documentation you do on all your work makes us all feel like we did the work on the car.. awesome work!
    Aug 2013
    St Louis metro (Illinois)
    5,796
    Beautiful car. You did a great job on what, IMHO, is the most beautiful large luxury sedan on the road today.
    Super Member Corey@OptimalDetailing's Avatar
    Jan 2013
    Norman, Ok
    565
    As always...amazing work Zach!
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    Excellent work Zach on the car and the write-up . Wheels and tires look fantastic, did you use OB Tire Gel full strength or diluted and how many coats?
    Super Member 10secdream's Avatar
    Aug 2013
    Sherwood Park, AB
    334
    Beautiful job Zach. I always enjoy your write-ups and your attention to detail. You truly gave that Audi the 'Finest' treatment.
  10. #10
    Super Member Dr_Pain's Avatar
    Nov 2012
    South Central, Louisiana
    2,196
    I saw the results on FB (on my phone over the weekend).... and seeing them on a computer screen this morning just makes it even more enjoyable. Great work as usual my friend!
    https://www.facebook.com/FlawlessFinishDetailing
    Dr. Claude Tremblay, Co-owner/Senior Detailer, Certified CQuartz FINEST Installer
  1. Replies: 19
    Last Post: 11-14-2019, 07:56 AM
  2. 2015 Audi A6, 2011 BMW 128iC, 2014 Audi TT
    By mjlinane in forum Show N' Shine
    Last Post: 02-15-2016, 01:18 PM
  3. Replies: 1
    Last Post: 01-10-2015, 04:50 PM
  4. Replies: 27
    Last Post: 05-15-2014, 10:05 AM
  5. Audi A6 CQuartz Finest Detail.
    By MirrorFinish in forum Show N' Shine
    Last Post: 11-08-2013, 11:40 PM
