Re: I hate Toyota brakes
Everyone is trying to solve this the wrong way.
Just stop slowing down.
Originally Posted by HotWhipT/A
Get ceramic brake pads. I had the same problem, until I upgraded. Autozone usually has their top of the line ceramic pads for most cars.
Depends on what you are after ... a daily driver, ceramics will be an upgrade in terms of less noise, wear and dust.
If you track your car, or are a 'spirited driver' ceramic will be a downgrade. Dust and noise are the compromise you get for better braking performance.
Originally Posted by Rsurfer
Imagine that run off is going into our rivers, streams, lakes or ocean after a rain.
Well seeing as I don't live in a watershed, my waste water all goes through treatment plant, and my brakes are no different in composition than anything else on the road (see street legal) ... tell me which pads i should be running that run on unicorn farts give off rainbows.
I dig your style
[QUOTE=ryanbabz71;675717]Again I have less than 3k miles not going to do a brake job on a brand new vehicle
Ryan
**** If you think off all the time most "Auto Geeks" spend cleaning their wheels (or looking at them dirty a day after you just cleaned them) and how filthy they get with some factory pads it really is worth it. Before I switched, I might spend an hour or so a week cleaning my wheels, just to have the dirty and dusty after 1 ride. The difference is drastic; especially with a German car. You go from full dust to no dust. The insides of the wheels stay clean also. Once I changed my brakes from factory BMW pads to organics, I never needed anything stronger than car wash to clean my wheels. Most likely, you will never need anything stronger than APC to clean them again if it's done somewhat regularly. And, no I can clean my wheels in less than 15 minutes, as most of what's on there just rinses off. Also, since the wheels stay cleaner, and there are no semi-metallic particles to clean off, the clear coat finish on the wheels doesn't get scratched up. With the cash some spend on pricey "safe" wheel cleaners, the switch will pay for itself in no time. Also, may aftermarket low dust pads are fairly inexpensive and if your rotors aren't warped you can probably just swap the pads. In my opinion, to do it when the car is new is the best time, that way the rotors are still fresh for the new pads. Front and rear dustless pads for my BMW were only about 125 dollars, super cheap, and that was for an M model. Best money I ever spent, as clean wheels really do go a long way towards giving a car a clean or "detailed" look IMHO.
By TMQ in forum Auto Detailing 101
Last Post: 09-13-2020, 05:32 PM
By asalesagent912 in forum Auto Detailing 101
Last Post: 03-19-2017, 12:54 PM
By AutoApollo in forum Auto Detailing 101
Last Post: 02-09-2016, 04:52 PM
By alpha1 in forum Off-Topic
Last Post: 10-01-2014, 09:36 PM
By BILL in forum Auto Detailing 101
Last Post: 03-04-2007, 06:02 PM
