Hello to all. After Spiros'es suggestion on posting a work of mine, here is a recent detailing I had done on a friends Miata NB.
This is my first work here so please be kind
Car had never been properly polished so this car's soft clear coat was not at its best. We first started with washing the car and then with claying.
Car's paint looked like that upon inspection. Many swirls, RDS and some deeper scratches all around the car.
So we got the car into the garage so the surfaces could cool down as the sun was shinning strong. Then started correcting with a DA polisher, a Lake Country Orange Cutting Pad and Menzerna PO203S.
Here are a couple of 50/50 shots I got of the rear trunk
For some spots where deeper swirls could not be removed easily by polisher, I used the help of some wet sanding
Which turned out really well after polishing
Rear trunk after polishing
Rear arch before
After
Rigth B Pillar wet sanded
Hard top polished. Rear glass is being cleaned in depth with Auto Glym Glass polish
We also removed hard top and cleaned the soft top with some APC solution and then treated the Vinyl surface.
In the meantime we also polished the headlights
Before
While wetsanding
After wetsand
Final
Car After Polish
We also polsihed the exhaust tip with some dodo metal polish and an MF cloth
Before
After
