Detailed: 2005 Acura NSX Long Beach Blue Pearl
This client found us via search for a detailer and was referred to us, once he got in contact; he came down to see what we could do with the car. He had attempted to do some polishing himself and was not able to achieve the results he wanted. The goal was to achieve as much gloss and depth as possible from this Long Beach Blue Pearl paint, being a triple stage: primer, base blue and candy blue pearl on top. Client knew that front end was repainted but we discovered while working on the car that most of was repainted; only roof, trunk and door molding were original paint. The paint shop matched the color well, but didn’t do too great of a job with the finishing touches (multiple runs, not blended well in some places etc). However looked well in the sun. Paint gauge was calibrated to be used on aluminum panels of the car, checked thickness of the paint and it was in 150micron range, so we were healthy in that aspect. Owner asked us to remove clear bra, which took us about 6-8 hours alone, because the quality of the bra was lacing and left most of the adhesive on the paint.
With all that said, we went the extra step to bring the car completely back to life, not that it was exactly resting near flat line either!
Products used
4” pads on PC and 2” pad on rotary for tight places)
Chemical Guys CitrusWash
Meguiars M105 with purple wool pad
Menzerna 203(power finish) with orange LC pad
Menzerna 85rd with black LC pad
P21S paint cleanser
P21S Total Auto Wash
P21S Wheel Cleaner
P21S finish restorer (exhaust tips)
BlackFire Wet Diamond (BFWD) paint sealant blue LC pad
Meguiars PlasticX on orange pad for taillights
Wolfgang Fuzion wax
Rejex (wheel sealant)
Poorboys Bold and Bright for tire dressing
Procedure:
Did test panel on spoiler, yellow and 105 left too much behind. Wool and 105 got everything in first pass, amazing how good this combo works.
* Clear bra was removed.
* Trunk and front hood underside was wiped with quick detailer; all hinge area was cleaned with brushes, q-tips and MF towels.
* 3 stage polish on whole car starting from back, front bumper was done last since adhesive was removed last. Whole car was sealed and left overnight to cure.
* Exhaust tips were in good condition so they were only polished with P21S finish restorer
* Engine was done as well, used TAW, brushes, and MF towels, rinsed with water from pump sprayer (not with water hose). But we forgot to take pics
* Whole car except for roof was done with: megs 105 and purple wool pad, Menzerna 203 and LC orange pad, Menzerna 85rd and LC black pad, P21S paint cleanser, BFWD and LC blue pad
* Roof - Menzerna 203 and orange pad, Menzerna 85rd and black pad, P21S paint cleanser, BFWD and LC blue pad
* Taillights - Megs 105 and wool pad on pass side, plasticX and orange pad on driver side, Menzerna 203 and orange pad, 85rd and black pad
* Wheels sealed with Rejex,
* Tires dressed with PB Bold and Bright
Onto pics
The wash
Car was rinsed and sprayed with TAW twice, washed with CitrusWash. Car was dried and water was blown out with air compressor from door jams and hard to reach areas, dried all leftover water, did test panel with clay and it was clean. Wheels cleaned with ez-brush and Swissvax brushes and p21s WC.
The trunk correction
Started with 3-stage polish on spoiler. Took spoiler off, cleaned old adhesive squares, replaced with new once. Polished underside of spoiler with Menzerna 203, wiped with p21s paint cleanser and sealed it. Left it aside.
Spoiler before
after
after
spoiler removed
dried up wax was in a lot of palaces but that’s from owner waxing it himself. At least it had protection.
took paint readings and they were healthy in 150 micron range
Under spoiler on trunk there was good amount of oxidation, which we wouldn't able to remove without removing spoiler, customer oked to remove it if it was needed.
Re: Detailed: 2005 Acura NSX Long Beach Blue Pearl
wow, great and amazing job, props on the photos as well. love how the fuzion turned out. looks wet
Working on a new sig..... still working....... if only it was as easy as buffing out swirls is...... Brad is my name.
Thanks.
wetness is not from fuzion but from proper paint correction, wax is only 5% of the final result. blackfire sealant helps with wetness as well. didnt see much difference between with and without fuzion applied. wax was more of "yes we did put wax on car"
I love the hood pictures with the sun reflection. Awesome finish.
Stop whining and crying like a baby! Life sucks...deal with it!
TOP JOB on my dream car!!!!!!I wish one day to have mine to show it
TOP JOB AGAIN MATE!!!!!
PERFECTION OF REFLECTION
Great work and great looking car, I love the color as well.
By J Z06 in forum Show N' Shine
Last Post: 09-08-2020, 09:45 PM
By Gav'sPurpleZ in forum Show N' Shine
Last Post: 08-06-2018, 07:51 AM
By Eric@CherryOnTop in forum Show N' Shine
Last Post: 08-07-2013, 01:48 PM
By Marc08EX in forum Show N' Shine
Last Post: 07-04-2010, 10:49 PM
By hondajake in forum Show N' Shine
Last Post: 10-01-2007, 05:13 AM
