01-27-2016, 10:43 AM
#1371
Re: Headlight Restoration-new UV sealant idea
Hello everyone, this is my first post and I would like to restore some of my headlights. Are you guys still using the spar method , if not what new products/methods would you recommend , and how long do they last before hazing returns?
02-02-2016, 01:32 AM
#1372
Originally Posted by jeff79
In terms of longevity which one would you say typically lasts longer??
honestly Im gonna say they last just about the same amount of time but the glasweld may have a little bit of an upper hand.
02-03-2016, 08:20 AM
#1373
My experience is that uv cured urethanes are far superior to spar varnish. I have seen some glasweld jobs start fading too early imo, but it's more the exception... whereas with spar varnish, it's the exception when it does hold up well. Varnish does not last a year in my experience.... usually not even 6 months. I have a test spot on my old durango...top side of the lens that faces the sky... that is still clear and present after 2 years. Varnish would have completed degraded by now. But I've had some issues with the gcure stuff not keeping lights clear. That's in the prep, conditions, or specific vehicle. Toyota Corolla 05-06 types for example...the lights oxidize so bad that a single coat just doesn't prevent the fading.
Later
02-03-2016, 09:11 AM
#1374
I been using Opti-lens as protection layer.
it is pricey side, but it will last long..... probably it will go bad before you run out them.
My second option would be gtechniq C4 trim coat.
I love gtechniq for easy application, again, expensive but little goes long way, and you can also use C4 for both trims and headlights so you will get more use out of it.
according to gtechniq, it will last upto 2 years.
Please like my page
Jae @ ONYX Detail Garage
02-05-2016, 07:28 PM
#1375
I have found the best way to apply the sealant (I use SafetyClear...but it smells and looks just like the stuff you guys are mixing) is a combination of the Scott blue towel, AND the foam brush. Best of both worlds. Foam brush is the most consistent applicator, but tons or air bubbles. The Blue towel is great, but sometimes hard to keep consistent.
Simply wrap a blue towel, AROUND the foam brush head. Soak the blue towel and foam brush, and brusk it on. Works fast and first time success for me...
02-07-2016, 04:02 PM
#1376
Made a video series on my methods. I actually offer two levels of headlight restoration and I wanted a example light to show customers.
https://youtu.be/F2uXXK_qzpw
www.JaxDetails.com
www.facebook.com/DentsAndDetails
I may be slow, but I do poor work.
02-09-2016, 12:42 AM
#1377
Thank you guys for tips and replies. @ Sweet The Details, I saw your post/thread and it was great.
06-22-2016, 04:38 PM
#1378
Do you have any durability results on the product you use? Just received mine and have seen 1 durability review and it was a little disappointed considering the claims by the company.
06-22-2016, 04:43 PM
#1379
Any durability results. I've seen 1 review and it was a little disappointing considering the claims by the company
06-23-2016, 03:24 AM
#1380
The two cars I've had less than perfect results were both Corollas, an 03 and an 05. I though it was the prep or conditions, because on both only one lens was iffy. Thanks for the heads-up, Mr Fusion. Meanwhile, the 02 Accord's lenses are still perfect at 21 months.
By geoguy in forum Show N' Shine
By ShineTimeDetail in forum Show N' Shine
Last Post: 06-08-2012, 09:47 AM
By websdown in forum Auto Detailing 101
Last Post: 02-03-2012, 02:19 PM
By truckbutt in forum Auto Detailing 101
Last Post: 08-21-2011, 08:57 PM
