» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    6,185
    Re: The daily with CQUK 3.0 + Gliss V1
    Quote Originally Posted by Sizzle Chest View Post
    I agree! Awesome looking vehicle/paint/everything! Well, well done!
    Thanks. It has served me well in the 19 years I have owned it. I got it to the look I want. It may not be supercharged but that is not a big deal. It gets me from point A to point B.
    Senior Member BadgerRivFan's Avatar
    Aug 2015
    Mt. Horeb, WI
    739
    I then chose to use Sonax Cut & Finish with Rupes green pads to go over the surface and remove whatever was left from Sonax CC36. There was very little defects on the paint. I was essentially removing the coating with this combo. Followed up with a prep wipe using Eraser.
    Mike - Always appreciate your detailed posts and have learned a lot from you, thank you. I'm curious as to why you chose Cut & Finish over say EX 04 06 if the paint had very little defects? I know your car has been repainted, so do you have more clear coat now than the original OEM paint? Just interested in how you arrived at your compound/polish and pad choice decisions...
    ​Al Schmidt
    "Adventure, is a car called Riviera..."
  3. Thanks The Guz thanked for this post
    Likes The Guz liked this post
  4. #13
    Jun 2013
    Lawndale, CA
    6,185
    Quote Originally Posted by BadgerRivFan View Post
    Thanks.
    It definitely does have more paint after the repaint. At least the paint gauge that I have says so. Cut & Finish on a cutting pad worked last time so I went with that but with a less aggressive cutting pad. Cut & Finish has a cut rating of 5 and EX 04-06 is at a 4. So EX 04-06 probably would have worked just fine. There are still a few areas that have deeper defects from the body shop and those could use a good compounding. They just don't bother me enough to take care of them.
  5. Thanks BadgerRivFan thanked for this post
  6. #14
    Jun 2013
    Lawndale, CA
    6,185
    Update time. I just hit the 13 month mark with the cquartz coating test on my daily driver. Thus far CQUK, TiO2 and CQUK 3.0 have held up nicely on my daily driver that sits outside 24/7 in the Southern California sun. There is some degradation starting to appear in the form of both versions of CQUK starting to lose its hydrophobic properties (aka beading).
    At the 12 month mark I dud give it a decon with ironx, foamed with Gtechniq Citrus Wash and a bucket wash with Reset.
    Next update will be right before polishing time which will put it a little over 17 months.
    I did not show the areas that have Gliss V1 on the side panels. Those are holding up nicely. Hard to tell if I am seeing the performance of Gliss or CQUK 3.0.
  7. Thanks Misterpaul, BudgetPlan1 thanked for this post
    Likes Misterpaul, BudgetPlan1 liked this post
  8. #15
    Senior Member van185's Avatar
    Oct 2011
    Western NC
    481
    Great post and thanks for the updates. Carpro is the only coatings I've used in years. Always seem to last. Keep the updates coming.
  9. Thanks The Guz thanked for this post
  10. #16
    Sep 2017
    Sweden
    2,470
    Awesome to see the update video Guz!
    Agree that it's looks really great where there is still holding up. A little odd that it's so big of a difference on the little areas where it has started to degrade. Could it be that it was gotten thinner applyied on those spots or something else that could have interfeared during the application or during the lifetime of it? Will be interesting to see how it looks like when you doing the next update before you take it off. If the other part or parts follows that much of noticeble degrading that you have now.
    I like how you just let it do it's thing and not topping it. And that's still have a very high contact angle and sheeting great after 13 months without anything extra applyied over it.
    Thanks for shareing your experience with the testing you are doing!
    Great video!
    / Tony
  11. #17
    Jun 2013
    Lawndale, CA
    6,185
    Great video!
    / Tony
    Probably just the UV here breaking it down similar to the other coatings I have used. Although CQUK 3.0 has proven to be the most durable compared to coatings such as Gloss Coat or Syncro.
    I have gotten comments on my other videos stating that a coating is failing because there is no maintenance product being used because it is a must to use one haha. My response is always the same. If a coating is so good then it should be able to stand on it's own without the need for a topper.
  12. Likes SWETM, BudgetPlan1 liked this post
  13. #18
    Senior Member BSoares's Avatar
    Mar 2017
    Exton, PA
    942
    I am so far very impressed with UK3.0 + Gliss v2. The self-cleaning ability is unreal. Syncro does give me more aggressive water behavior but it doesn't clean itself as good as the CarPro combo does. My wife's car looks like it was just washed every time it rains. I love it and hope it lasts more than a year (when her lease is up and we give the car back to Honda).
    Bruno Soares
  14. Likes BudgetPlan1, SWETM liked this post
  1. Product Review - CarPro GLISS (Long Term)
    By TroyScherer in forum Product Reviews
    Last Post: 07-06-2018, 08:33 AM
  2. UK and Gliss applied
    By Jeremy1976 in forum Show N' Shine
    Last Post: 05-22-2018, 09:52 AM
  3. Gliss “best by” date
    By parshisa in forum Auto Detailing 101
    Last Post: 05-11-2018, 12:16 PM
  4. When will AG have Carpro Gliss?
    Last Post: 03-04-2018, 06:17 PM
  5. CquartzUK sticky, gliss smooth?
    By RiverCityAutoSpa in forum Auto Detailing 101
    Last Post: 12-10-2017, 01:39 PM
Members who have read this thread: 56
» August 2019
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
