» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Jul 2016
    2,698
    Re: Exo and essence question plus nice reflection shots.
    Starting this project tomorrow. Think I'm going to use 3800 then coat. I may use something on a polishing pad first if it looks like it makes a difference on my test spot. I might polish with the new rupes Millie fine polish then jewel it with 3800.
    I gotta see the defects under this new work light I bought
    Senior Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    3,402
    Quote Originally Posted by fightnews View Post
    What do think about pairing up the gyeon polish or essence with the exo?
    I'm not familiar with the EXO products. sorry.
  3. #13
    Senior Member Calendyr's Avatar
    Jun 2013
    Montreal, Quebec
    3,259
    Quote Originally Posted by BadgerRivFan View Post
    Check out 512detail's comments over on the Autopia Forum regarding Essence and EXO. I seem to recall that in his experience they did not work well together. It was probably a good 18 months+ ago that he tried Essence with a number of different toppers. YMMV of course.
    If you are not 100% set on using Essence as your final polish before coating, check out Gyeon Primer as an option. I've found it to be a little less finicky than Essence (although I do like Essence) and the gloss is terrific. There are no fillers in Gyeon Primer if that makes any difference to you. I've topped Primer with several different hybrid waxes and it's worked great. I've seen zero comments out there about using non-Gyeon coatings on top of Gyeon Primer though. It would be interesting to learn if it is compatible with competitor's coatings.
    Thanks for the info. I received both EXO and Crystal Serum Light today. My normal prep is Essence before applying the coating (normally I use McKee's 37). So I will have to switch that to M205 then.
  4. Likes BadgerRivFan liked this post
  5. #14
    Jun 2013
    Montreal, Quebec
    3,259
    Quote Originally Posted by DaveT435 View Post
    Are you doing CSL and topping with EXOv4 or just using EXO as a stand alone?? I've been using EXO for a few years. Didn't use much v3 but overall I've been really happy with it. I used v2 as a stand alone on a couple vehicles with great success.
    You definitely wouldn't be the first to polish off a coating long before it actually needs to be removed. lol
    How many cars can you usually do with a bottle of EXO? Mark Barger told me it's about 3. Is that your experience as well?
    Trying to figure out pricing for both EXO and CSL.
  6. #15
    Jul 2016
    2,698
    Quote Originally Posted by Calendyr View Post
    what size bottle? I got the 30ml it says 1 car but idk if it 2 coats on 1 car or 1 coat on 1 car. They recomend 2 coats so im hoping its at least 2 coats.
    The exo v4 might work better with essence then the v3 did idk?
  7. #16
    Jun 2013
    Montreal, Quebec
    3,259
    Ya 30ml bottle. I did a Lexus Sedan today using it. So it took about 3/4 of the bottle to do the car and mags. I applied 2 coats.
    So if you can only do 1 vehicle with 1 bottle, it's not something I will use for my packages. First, doing 2 coats instead of one is a major waste of time. Basically adds and hour to the detail. Second I got EXO in a kit with Crystal Serum Light. Together the total was 140 CAN$, will have to check how much of that is CSL and how much is EXO but just for argument's sake, let's say EXO costs 60$ and CSL costs 80$. If I compare that to McKee's 37 Paint coating, this products costs me (with shipping included) 85$ and I can do 5 cars. So 17$ per car and only 1 coat needed so I save an hour as opposed to 60$ for the same car and more time to apply.
    Mark Barger mentionned EXO is extremelly Hydrophobic. I have not seen it once cure but I will take his word for it. McKee's is not overly hydrophobic. Water will not stick to it but it doesn't have the effect that looks like a force field when water hits it and just flies away. Still, we are talking about 18-24 months coating with EXO and 2-3 years with McKee's. So for me the clear winner is McKee's for my base product.
    I will still add CSL to my offerring with the option to top it with EXO. CSL is not very hydrophobic according to Mark, so that might leave clients disapointed.
  1. A few reflection shots
    By Don M in forum Show N' Shine
    Last Post: 05-29-2017, 08:26 AM
  2. Best Reflection Shots on a White Car
    By ARizzle in forum Auto Detailing 101
    Last Post: 11-21-2012, 01:08 PM
  3. Reflection shots
    By mswerb in forum Show N' Shine
    Last Post: 09-01-2012, 01:50 PM
  4. 00 Corrolla Reflection shots pt.1
    By Beerwulf76 in forum Show N' Shine
    Last Post: 03-25-2012, 08:32 PM
  5. Reflection shots-'05 Silver F150
    By netspec in forum Show N' Shine
    Last Post: 04-17-2008, 08:24 PM
Members who have read this thread: 56
» September 2018
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
