Re: 2018 Ford Explorer
Your are always knocking it out of the park!!!! Whenever I detail, I try to compare my detail to yours. Great job as always!!
Thanks everyone!
Thanks Paul!
prin: Appreciate your comment...I've seen your work here and on IG, and it's great!
Scott Harle
Autodermatology
#autodermatology
Awesome work and write up and pictures as always Scott! You always delivering high quality jobs. That's very much of metallic in that paint and think it is glisstering even more in real life.
/Tony
Excellent job and awesome car. I don't understand how you can get all the contours with a 21? It stops spinning whenever it hits any type of shaped panel doesn't it?
Is that a coating you had to get certified for? How long did it take to do it all? How long between layers?
Thanks Tony!!!
fightnews: Thank you! It won't stall on curved panels/etc. If you see the pad start to stall, move the machine around some to find the 'sweet spot', also on some curved areas you can use the edge of the pad--I believe there are a few threads on this technique, I will look to see if I can find them!
Yes, that is a pro coating. I probably had around 24 hrs into it. I waited approx. 4 hours between the two 9H coats. (they recommend 2+) and then I topped it the following morning with their top coat.
Scott Harle
Autodermatology
#autodermatology
