Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    A 17 year old's sins erased-1999 orange Camaro with 21k original miles
    I was looking forward to doing this car. I can't remember doing an orange car before. This 1999 Camaro has 34,000 km on it which is equivalent to 21,000 miles....it deserved to look like the low mileage car that it was!
    Here it is when it came to me:
    The wheels had been powder coated:
    The black top and side panels were heavily swirled:
    The car was quite heavily swirled:
    There were a few challenging spots to fill too: one right on the tip of the nose and one scratch along the underside of the back bumper as well as many, many miscellaneous different ones:
    To start, the wheels and tires were done. The barrels were cleaned with Tarminator, followed by Zep Citrus. The faces were cleaned the same as well as a demoted wash mitt and Megs HW. The tires were cleaned with Zep 505 and the wells with LATA. The barrels were shot with Aqua Bead after cleaning them to give them some protection since I wasn't going to be removing them for this job. I didn't charge the customer for that.
    The car was then washed with Megs HW followed by a decontamination step of IronX paste. It was then brought inside and clayed with a CarPro Clay Towel. The wheels, tires and wells were then blown off with the Master Blaster.
    Now it was time to see what would work on this heavily swirled, 17 year old paint. My usual combo of Flex 3401 + TB black wool and M100 was not cutting it (literally). I had to go old school on this old school car: Dynabrade rotary at around 1400 rpm with a fair amount of downward force. That was literally the only thing that would cut down deep enough to remove a satisfactory amount of swirls and scratches. I really wanted this car to look great! Now that I found out what was going to work well, I sparked up a beautiful cigar that Don had sent me: a "La Gloria Cubana Serie R Black". Strong and lovely! Kinda like the job I was doing. Since I was being so aggressive with that first step, I decided to follow it with a mid aggressive step that I normally don't have to do. That step was Flex 3401 + B/S yellow pad + M100. That was my insurance policy against any rotary marks showing...although to be honest, I couldn't see any. My final step was Flex + M205 + white B/S. I was quite happy with the outcome. The cost range that the customer had in mind did not allow for perfection, and frankly, I didn't want to be thinning out the clear too much anyway. I think this was a responsible, yet aggressive combo. All the panels got this as well as the rear tail lights.
    The black roof and side panels were a real chore. I used the same procedure on them but some sections took 4-5 passes to remove the marks. I took 1.5 hours just to do that area. It really showcases the car with the contrast, so it was important to me that it be done very well. You'll see how it turned out.
    After being prepared for coating, 2 coats of Americoat were applied to the wheels, paint, head and tail lights as well as side and rear glass. The tires were shot with Opti Bond via my air gun. The windshield got treated to DG Rain Repel.
    I was lucky to have a glorious day in which to shoot it. Here are the results with the sun high in the sky at noon:
    No more paint chips visible on the front end:
    Nose chip filled in very nicely I think:
    As did the one on the rear bumper:
    Not perfect, but much better.
    The rear pipes were hand polished with M205 and coated too:
    Happy camper driving away....
    Feb 2016
    52
    Re: A 17 year old's sins erased-1999 orange Camaro with 21k original miles
    Great breakdown of the challenges and what you tried through the process. (London ON here)
    Keep posting your work!
    I'm a FG400/SF3500 kinda guy....a MF cutting pad with M105 wouldn't have done the job initially?
    Super Member FrankS's Avatar
    Jul 2013
    West Palm Beach, FL
    1,560
    Nice job Richy!
    What pad and compound did you use with the rotary on the first step?
    Sep 2014
    PA
    651
    Really appreciate how you break down your processes. Fantastic job on the car! Thanks a bunch Richy!
    Super Member AZ Mike's Avatar
    Jan 2014
    Phoenix, Arizona
    1,128
    Quote Originally Posted by FrankS View Post
    Beautiful job.
    AZ Mike aka "Repeat"
    May 2011
    1,205
    Richy, excellent work as always. You turned me onto the TB wool pads, and they cut very well, I'm just curious, have you tried a long throw, mf pad and Flat Top? This is my heavy cut combo now. Thanks.s
    Mar 2007
    Windsor, Ontario
    5,158
    Quote Originally Posted by brad911 View Post
    Thank you! I am out of M105, but M100 is pretty close to it in cut. I have found that even the cutting mf's don't have 1) the bite that the TB's do and 2) don't finish down nearly as well (especially when using the Flex).
    Nice job Richy!
    Thanks Frank. I used M100 + TB black wool, the same combo I tried first with the Flex.
    Quote Originally Posted by 7.3powerstroke View Post
    Thanks kindly. I think that's how we all learn from one another is to do it that way.
    Quote Originally Posted by AZ Mike View Post
    Beautiful job.
    Thanks kindly Mike!
    Quote Originally Posted by Billy Baldone View Post
    Yes, I have tried both the cutting and finishing mf pads with the Rupes 21. They don't cut as quickly or as deeply, nor do they finish down as well as what I can do with the TB pads. I keep buying them thinking they'll improve, but the bar is set VERY high with the TB's. That's my opinion and my experience. I know a lot of people do well with the mf pads. I just don't like them as much.
    Super Member LSNAutoDetailing's Avatar
    Jun 2014
    Chandler, AZ
    3,359
    Richy, great work! Scary that 100 & Flex didn't cut the mustard at first... Good thing you worked the rotary well.
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,881
    Nice work!!! Great thread and pictures too! It used to be swirl city~not anymore!
    Love those TB blacks!!!!
    Scott Harle
    Autodermatology
    #autodermatology
  10. #10
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Great job my friend! Would've been perfect if you could've talked the customer into taking that front plate off. Are they required in Canada? Glad you enjoyed that LGC SerieR.
  1. 2008 GMC Sierra with 76,000 Original Miles
    By UncleDavy in forum Show N' Shine
    Last Post: 10-22-2017, 10:39 PM
  2. 5000 original miles on 2001 Z06
    By richy in forum Show N' Shine
    Last Post: 07-16-2012, 11:29 PM
  3. 1970 Oldsmobile Cutlass - 28,948 Original Miles
    By Mike Phillips in forum Off-Topic
    Last Post: 02-17-2011, 05:40 PM
  4. 1970 El Camino 63,000 original miles
    By Wendell Jarvis in forum Show N' Shine
    Last Post: 07-16-2010, 01:51 PM
  5. 2000 Ford F-350 Dually - 48k Original Miles - EHUTH1
    By ehuth1 in forum Show N' Shine
    Last Post: 04-06-2007, 06:54 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
