Results 1 to 9 of 9
    Junior Member trojanone1's Avatar
    Feb 2016
    Sioux Falls, SD
    38
    First Time detailing an RV
    Hello everyone,
    My wife and I are about to purchase our first camper, a 2005 Trail Cruiser 21MBH, and I am getting all the tips and info I can get before I start detailing it. I have done some reading on the RV & Motorhome Detailing page, but have a couple questions. Looking at using Duragloss 501 for an AIO of sorts to clean the fiberglass exterior with 7424XP and 5.5" orange CCS pads. The fiberglass isn't too oxidated, but still needs some TLC. Would you recommend anything else besides the Duragloss 501? The price of the 501 is attractive plus the AIO would make it simpler to use.
    My second question is can I use degreasers on fiberglass? Specifically cleaning the caulk seals around the windows, doors, and roof? What would you recommend for that?
    Thanks in advance.
    In time out
    May 2016
    Re: First Time detailing an RV
    Degreaser will etch the exterior. However the drip marks left by degreaser can be buffed out with compound and a buffer. Good luck.
    Medium aggressive polish light to medium oxidation. Google a product called longevity. It's a sealant that also removes light oxidation. Then u will have 6-9 months protection. Let me know if u have any other questions.
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    I won a bunch of the McKees TV stuff and have alot left over too that I would gladly pass along for free if your willing to pay for shipping. PM me and I will give you the run down on what I have left and what I liked and didn't in the bunch.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    Super Member Jomax's Avatar
    Jan 2012
    Arizona
    1,422
    I use a degreaser in my pressure washer detergent tank when I do a trailer.
    I pressure wash and spray the degreaser and scrub with a trailer brush. This cleans it REALLY well and also takes off some oxidation.
    Id then use a AIO made for fiberglass from the marine 31 Line.
    http://www.autogeekmobile.net/marine...h-and-wax.html
    David 2000 Ford F-350 DRW CCLB BLACK/GOLD
    Wish list:
    Everything Mike has in his garage for detailing
    Newbie Member NuthinFancy's Avatar
    Dec 2015
    Ocala, FL
    Caulking kind of depends on what material it is and how well it's applied. Nice smooth bead- Magic eraser works well. Lumpy, bubbly bead. Apply degreaser to microfiber, let it cook a bit, brush with soft tooth brush, wipe off with microfiber and or MagicEraser. Not a whole lot of fun
    RV Wash & Wax, Repairs, Renovations, Box Trailer Conversions, Woodworking, Honey Do Lists.
    Sep 2015
    6,281
    Quote Originally Posted by trojanone1 View Post
    Hello everyone,
    Thanks in advance.
    I would not use apc on that it will fade it more.Bleach with some brushes work great around caulking and roof.Is the caulking white or clear.when washing roof you will need someone on the ground rinsing your residue off the sides or etching may happen.Get a cheap pump sprayer fill it with outdoor bleach and fire away on the roof.Becareful the equiptment may be brittle good luck.
    Jun 2011
    2,711
    Just in case some reading this into the future have zero experience using bleach...
    The only problem I have with recommending someone to use any kind of bleach, on any detail or other type of job, is not talking about proper precautions when using bleach.
    The possibilities of a person mixing it, or not thoroughly rinsing it off before applying another product can reek havoc. Even outside the resulting reaction from mixing something with bleach can have devastating and deadly effects. I've seen this first hand and it is NOT something I'd want to witness again.
    Mixing bleach with other chemicals is a disaster waiting to happen. It can majorly scar your lungs or kill you and it can all happen in an instant. PLEASE EDUCATE YOURSELF ABOUT THE DANGERS OF MIXING BLEACH with other chemicals.
    You will be fine using BLEACH as long as you DON'T MIX IT WITH ANYTHING ELSE and RINSE/FLOOD w/WATER THOROUGHLY. When you're done rinsing...well, rinse it some more then take a 10 minute break and walk away from the area just as a precaution. (Remember...working up on top of an R/V turns a quick escape into a turtle race...so, be sure and rinse any bleach thoroughly before attempting to use another cleaning product.)
    Bill
    Jan 2012
    Arizona
    1,422
    Quote Originally Posted by Hoytman View Post
    X2
    This is why I'd NEVER use bleach. I prefer APC.
    Wish list:
    Feb 2016
    Sioux Falls, SD
    38
    Hello everyone! I almost forgot about my post, but I appreciate the advice. I got the camper cleaned, not 100%, but better than the previous owners did. I wished I took before/after photos because the fiberglass was in definite need of polishing. I ended up using a diluted mixture of Simple Green to wash the exterior and scrub the dirty caulking with magic erasers. That did the trick and I followed up with Meguiars Gold Class and gave it another bath. I misjudged the number of pads for my Porter Cable that I needed for this camper, but used four orange CCS pads with Duragloss 501 on the front and rear of the camper. Only had four orange CCS pads so finished up the camper with white flat pads. In all, the camper could use another polishing and I couldn't get the roof cleaned. Looks like mold spots on the roof.
    I fell in love with the Duragloss 501 that I ended up doing my wife's white Impala with it and love the results.
  1. First time detailing
    By photocrazy in forum Auto Detailing 101
    Last Post: 05-20-2017, 06:26 AM
  2. First time detailing.
    By taxi_dub in forum Auto Detailing 101
    Last Post: 01-18-2014, 02:51 PM
  3. First Time Detailing!
    By Canuck2.0T in forum Auto Detailing 101
    Last Post: 04-09-2012, 09:04 PM
  4. First time detailing
    By molarman in forum Auto Detailing 101
    Last Post: 06-15-2010, 10:55 AM
  5. Mon-Fri Job Gone: Maybe It's Time for Full Time Detailing
    By Totoland Mach in forum Off-Topic
    Last Post: 11-05-2009, 07:07 PM
