No reason to, the Mini is a highly capable machine as is and has plenty of power to correct when used for what the machine was designed for. It does a great job in the tight areas. i will say this, the Rupes pads are a must whether you choose to use the polishes. It's design along with the pad design allows you to cut into tight areas because of the bevel. Not too mention it will toast most other pads if run to high.
2019 Nissan Rogue SL
If you think you'll want a tad more power to the surface
Duetto with 3in kamikaze backingplate.. Just not sure if the bigger shroud will protrude into the vision of BP/pad
