Re: Rupes Mark II , Mark ii NICE!
Originally Posted by Chris@AutoCleanse
Why you say the backing plates don't fit from version 1 to version 2. Do you mean thread size, thickness of plates or something totally different. Thanks in advance.
Yes size of slot is different. Thickness is also different. Weight is identical down to the gram!
(Mark I top, Mark II bottom)
There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
Thanks for the info buddy. ^^^^^^^^^
If they only had a trade up program.....
How does the Mark 2 compare to the boss regarding stalling
I constantly kept reading about how the mark1 stalled on panels which is why i ended up with the boss.
My boss hasnt stalled on me yet, and im new to machine polishing .
So obviously the bigger watt motor compensated for the stalling issue... but it does generate allot of heat wbich i feel will comprimise the pads longterm durability. .
IF you also cured the stalling issues with your more efficient motor while retaining same wattage i then think you guys took the better route
as you will generate less heat then the boss while potentionaly producing less heat then the mark 1..
Thoughts?
Originally Posted by Todd@RUPES
While I won't comment with 100% certainty...
The MK II backing plates that I have (pre-production) bolt up to the MK I, no problem. However, the earlier MK I backing plates (small slot) will not bolt up to the later MK I nor the MK II.
Todd will this backing plate fit on the Mark ll 21?
Rupes LHR 15ES 5 Inch Backing Plate
I understand it's not recommended, but I'm looking to use the 5" backing plate on the 21 Mark ll
2015 Audi //S4 (Ibis White)
1995 BMW ///M3 (Alpine White)
Last Post: 09-14-2016, 03:13 PM
By Elger in forum RUPES BigFoot Oribital Polishers
Last Post: 07-06-2016, 09:16 PM
By Elger in forum Wool & Foam Buffing Pads
Last Post: 06-21-2016, 09:32 AM
By The Guz in forum Show N' Shine
Last Post: 05-21-2016, 07:46 AM
By alegend in forum RUPES BigFoot Oribital Polishers
Last Post: 05-15-2016, 08:21 AM
