» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Member Buracho's Avatar
    Nov 2015
    50
    Re: Rupes Duetto with 3" backing plate....What a perfect world it would be :)
    Quote Originally Posted by LimitlessDetail View Post
    Dont forget any use of 3rd party backing plate voids the warranty that comes with the machine...Something to keep in mine.
    True that.
    Thanks.
    Nov 2015
    50
    Quote Originally Posted by NextLevelDtail View Post
    So can you put a 5 inch bp on the mini ?????
    Hmmm....didn't think of that. I think I has more than adequate Power to handel 5 - 5.5 inch pads and will be economical as well. Balancing is going to be an issue like Duetto tho.
    Anyone care to input?
  3. #13
    Senior Member custmsprty's Avatar
    Apr 2012
    7,419
    I have the 15, the Duetto and the Mini. As Mike Phillips has stated in the past, these tools are all part of a system. If you do this as a profession you'll have more than one tool as they are needed for different situations. If you're doing this as a hobby and don't have the extra cash for multiple machines I would suggest a PC or GG6 that you can use different LC BP's on. I wouldn't try to put a 3" BP on my Duetto or a 5" BP on my Mini. This isn't what they were designed for. Just a note, the mini has a smaller ring arounf the BP, if you put a 3" BP on a Duetto you don't necessarily get into tighter area because the bp ring is much wider and you will bump into things like mirrors etc.
    2019 Nissan Rogue SL
  4. #14
    Nov 2015
    50
    Quote Originally Posted by custmsprty View Post
    Thanks for the reply. It makes total sense. I am a hobbies and I just wanted the best of both worlds haha
    I will go with the Kamikaze then. Cheers
  5. #15
    Senior Member Mantilgh's Avatar
    Dec 2014
    Boonsboro, Md
    2,722
    I'd post a picture of the 3" BP on the Duetto if the gallery wasn't acting up.
    It probably won't help to much getting into tighter places, maybe just better for working on thiner areas like B-pillars.
    ____________
  6. #16
    Nov 2015
    50
    I totally agree. That is what I panned to use it for. But for tight places I will use a rotary 3 or 2 inch pad and extension, that way you cover every inch and get precise cutting/polishing.
  7. #17
    Senior Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    Quote Originally Posted by Mantilgh View Post
    See what you can do posting the pic cause I am considering buying the lhr75e
    But if I can just buy the duetto and use the 5 and 3 I'll just do that any change in performance when going 3
  8. #18
    Sep 2013
    Australia
    The problem with this would be that the mini BP + pad is lighter than the duetto's so you would needed to somehow reduce the weight of the duetto's BP so that it and the pad ends up weighing about the same as the mini's. I don't think it's possible.
    Making the mini's BP heavier for use with a duetto is far easier. But then you have the larger shroud of the duetto getting in the way.
    This is why I still prefer the porter cable type DA for polishing tight areas (even over the mini) if I'm not going to get the rotary out.
  9. #19
    Senior Member Rsurfer's Avatar
    Jan 2007
    12,631
    Quote Originally Posted by GeeWhizRS View Post
    If anyone is after a 3" backing plate for the Rupes LHR12 or LHR15, give me a shout. I can make one on a 3D printer using very strong filament. This has been tested and works fine. The weight is within a few percent of the original so vibration is not an issue. This will allow you to use the BF100 range of Rupes pads. ����
    Gee whiz, you're trying to sell backing plates on AG forum?
  10. Likes PaulMys liked this post
  1. To those of you who have put the 5" backing plate mod on your Rupes 21....
    By Buff-N-Glo in forum RUPES BigFoot Oribital Polishers
    Last Post: 04-01-2017, 12:06 PM
  2. RUPES 2" Backing Plate not for use with the rotary connector and the RUPES Nano iBrid
    By Mike Phillips in forum RUPES BigFoot Oribital Polishers
    Last Post: 01-22-2017, 10:37 AM
  3. Rupes backing plate
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 06-03-2015, 11:26 PM
  4. Rupes 15 vs Rupes 21 w/5" backing plate
    By expdetailing in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-02-2014, 11:52 AM
  5. Griots 6" backing plate VS. Lake Country's backing plate
    By ryanmcg1 in forum Product Reviews
    Last Post: 09-29-2011, 11:29 PM
Members who have read this thread: 23
» October 2020
27282930 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
