» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Nov 2009
    Pasadena, CA
    12,614
    Rupes LHR 15 Mark III - pad and speed
    Rupes recommendation is correcting/polishing at speed 4, generally speaking. You may increase speed on concaves or if the surface is grabby and not allowing proper rotation. Use Rupes pads.
    '03 Corvette Z06
    May 2020
    Re: Rupes LHR 15 Mark III - pad and speed
    I wanted to try out Rupe's new polishes I own two cars, a 2013 Chevy Cruze (black metallic paint) and a 1994 Ford Mustang convertible (Rio Red). The paint on them is good; however, with the Cruze being a black car, it will show anything.
    What speed settings would you recommend for the following (I am still using the Rupes LHR 15 Mark III);
    1) Rupes ultra finishing polish (Uno pure) with Rupes white pad. Is it safe to use this combination once a year? I would assume this would remove very little clear coat.
    2) Rupes high-performance fine polishing compound (D-A fine) with Rupes yellow pad. Would this combination take off much clear coat (would it be safe to do once a year)?
    3) Meguiar’s hybrid ceramic wax with a Lake County black pad. I usually do this at a very low speed, such as 1 or 2.
    I do own a Rupes blue pad and the old Rupes Zephir Gloss Coarse Gel Compound (I think that has been discontinued)? However, I very rarely ever use that combination, the only time being if there was significant damage to the paint.
    Thanks for the info!
  3. #13
    Super Member Todd@RUPES's Avatar
    Dec 2007
    Orlando/Oviedo
    409
    Quote Originally Posted by Mustang94 View Post
    Hey Mustang94,
    Both combinations you listed are fairly mild. While I would never say that anything is 100% safe to use any number of times, for any number of years... assuming your technique is solid and your paint is healthy, you could use either combination a large number of times with minimal impact on paint thickness. Of course, there are always exceptions to the rule, and even the mildest combination run on speed 5 with heavy pressure directly on the edge of the paint can do damage..
    Remember that paint correction (regardless if we are sanding, compounding, or just light polishing) is a process that requires removing the paint above the scratch to create a new level surface. One bad wash can require a half a day of paint correction.. which is effectively saying that one pad wash removes more paint (in isolated areas) than a light polishing session. Focus on good washing and drying techniques and your paint will reward you with a happy and long-service life.
    As far as speeds, I would use 2-to-4 for the white pad, and 3-to-4 for the yellow pad.
    Enjoy!
  1. RUPES Giveaway! Autographed RUPES 21 Mark II Up For Grabs!
    Last Post: 09-14-2016, 03:13 PM
  2. Recommended pads for Rupes mark ll and Rupes mini
    By Elger in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 09:32 AM
  3. Replies: 29
    Last Post: 05-21-2016, 07:46 AM
  4. Rupes LHR 21 Mark II =>VS LHR 15 Mark II Which one to get?
    By alegend in forum RUPES BigFoot Oribital Polishers
    Last Post: 05-15-2016, 08:21 AM
  5. Rupes Mark II , Mark ii NICE!
    By SonOfOC in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-25-2015, 04:20 PM
Members who have read this thread: 34
» June 2021
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 123
