» Detailing Classes
Results 21 to 30 of 31
  1. #21
    Senior Member Rsurfer's Avatar
    Jan 2007
    12,266
    Re: New to Rupes - Trigger Pull Question
    Quote Originally Posted by gofast182 View Post
    Turns out my wife got it from Amazon who fulfilled the order via detailerdomain. She has made initial contact for the return/exchange. Hopefully they don't give us grief.
    I just got a big Autogeek box with my Rupes pads and Polish Angel ceramic coating. It's hard to resist trying it out.
    Quote Originally Posted by Vanquish Auto View Post
    If you have any trouble through amazon try going directly through Rupes. But I don’t think you will have a problem getting it sorted. I say it is. It shouldn’t take too long to everything straightened out.
    Should have bought it from Auto Geek, no worries.
  2. #22
    Member
    Jan 2019
    55
    ^ obviously, but I was kind of out-of-the-loop on this one!
  3. #23
    Jan 2007
    12,266
    Gotca, show gratitude to the wifey.
  4. #24
    Member
    Jan 2019
    55
    The polisher is currently on its way to Rupes USA for examination and possibly repair. I spoke to someone named Will on the phone who was very helpful. They need to feel it first-hand to know if it's normal or not but they seemed to think it should be a smooth trigger pull. Will also seemed to suggest that even if it is normal when it's apart they will look at it and try to make it feel right for me. Here's hoping it's a quick and satisfactory process.
    Edit: In parallel my wife requested to return the tool through Amazon. Even as of today detailersdomain has not responded to the Amazon return request. I'm surprised because I've met Phil and I thought he ran a top notch operation.
  5. #25
    Jan 2007
    12,266
    Just pulled a brand new Mark III LHR 15 out of the box and the trigger pull is smooth at all speeds.
    You did the right thing by sending it to Rupes USA since it's brand new. No point in going through a middle man, time saved.
  6. Likes rlmccarty2000 liked this post
  7. #26
    Apr 2015
    PGH, PA
    1,424
    If you already have a markII or Griot boss in good working order then no, not worth it.
    If you have a 8mm machine or rupes ES or a polisher on last leg..worth the upgrade.
    Mark III is just a mark II in a Mille case, variable trigger(they're awesome,but not needed) and a more narrow power band..no improvement on actual torque(lack of stall-ability)
  8. Likes DETAILROOKIE liked this post
  9. #27
    Member
    Jan 2019
    55
    Update: My polisher is on its way back from Rupes. They replaced a defective switch in the trigger assembly. Hopefully that solves the issue!
  10. Likes rlmccarty2000 liked this post
  11. #28
    Jun 2016
    233
    Good to hear. I’m glad you got everything sorted out. I hope you enjoy it when you get it back.
  12. #29
    Member
    Jan 2019
    55
    Ironically, I told my buddy I just got the Rupes and we scheduled a date for me to come over and polish his race car, last Sunday. In the meantime I sent it back because I didn't want to use it if something wasn't right so I had to do his car with my 7424XP.
  13. #30
    Senior Member DetailTrail's Avatar
    Oct 2015
    129
    That's an expensive machine I'm glad it worked out.
    My Mark lll 15 is smooth when running,
    I can feel a slight tightness at the end of pull, when not running, like it has something to do with the lock button engaging in that area.. ??
    Great machines !! Along with Griot's Boss, Flex 15
  1. About to pull the trigger on a Rupes 15 but.....
    By TMQ in forum RUPES BigFoot Oribital Polishers
    Last Post: 03-15-2017, 06:14 PM
  2. Going to pull the trigger on my first DA
    By solar07 in forum Auto Detailing 101
    Last Post: 03-23-2015, 08:25 AM
  3. I'm about to Pull the trigger
    By Mayassa in forum Flex Polishers
    Last Post: 10-01-2012, 12:18 PM
  4. Metro Blaster question before I pull the trigger tonight!
    By Grifftech in forum Auto Detailing 101
    Last Post: 05-25-2012, 09:58 PM
  5. Should I pull the trigger ?
    By NiSyam in forum Ask Mike Phillips your detailing questions!
    Last Post: 11-16-2011, 06:39 PM
Members who have read this thread: 8
» February 2020
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
