Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Nov 2015
    Los Angeles, California
    13,752
    Re: Original Vs Current Rupes Microfiber Pad Observations
    Prep wipe must be done.
    That stipulation didn’t seem to apply to my “light colored paint”.
    There’s alot of people who are quik to point towards light colored or white colored vehicles as if we or in this case I can’t spot haze just because the paint is white and I disagree with that.
    That’s like saying someone could pour you a drink with some store brand whiskey & cola and you wouldn’t be able to tell the difference between that and the good stuff because it’s mixed with cola.. You can’t hide cheap booze the same way white paint can’t hide haze... Either you know what you’re doing and achieve good results or you don’t no matter what color vehicle you’re polishing.
    We can see regardless of what color the paint is.
    Nov 2015
    13,752
    *knock on wood* lol.
  3. Likes oneheadlite liked this post
  4. #13
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,372
    Different lighting plays a role in how well you can see remaining defects. If you inspect with enough different lighting sources for enough time you can spot them no matter what color the paint is. Sometimes the inspecting is the longest part of the entire detail.
  5. Likes Eldorado2k liked this post
  6. #14
    Nov 2009
    Pasadena, CA
    12,615
    Couldn't disagree more. Haze will DEFINITELY be harder to spot on light colors as opposed to dark. Especially light metallics.
    '03 Corvette Z06
  7. #15
    Nov 2015
    13,752
    Yea but it’s still visable. All it takes is a close look or proper lighting. It’s not invisible.
  8. #16
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Step up to the Lake Country HDO Heavy Cut Microfiber Pads.
    They’re a clear cut above past renditions of microfiber pads because they were engineered for modern day long throw polishers. They feature a cooling chamber, fibers that don’t matt down quite like the other microfiber pads + they’re built tough and won’t delaminate, and best of all they cut like a chisel and finish down like a foam polishing pad.
    Top of the line pads. IMO it gets no better.
    6.5 inch Lake Country HDO Fiber Heavy Cutting Pad
    I have the standard ones, without the hole, and yes, they cut like crazy. I'd have to A/B them with the others. I bought them intending to use on the PC. So far, the original Buff and Shine pads are my favorite on the PC.
  9. #17
    May 2013
    Rochester Hills, Mi
    6,016
    I wouldn't go that far. With that light colored paint, haze isn't going to be clearly evident. Try that same combo on black paint and it won't finish like a foam polishing pad.
    If I see a white-ish, or bluish halo after paint prep, it isn't a show car finish for me. Easy to see on dark, but my car is white, and my girl's is bright yellow. I can see it clear as day.
  10. #18
    Aug 2016
    199
    Btw have anyone tested Lake Country low lint foam interface woolpads? How do they compare to Rupes wool pads?
  11. #19
    May 2013
    Rochester Hills, Mi
    6,016
    Quote Originally Posted by Joel1979 View Post
    I tried one, but didn't have any Rupes wool to use it against. I used it with M100 on a 3401, and it quickly removed all the defects from some pretty "resistant" GM paint.
    For being "low lint", they still linted - even after seasoning them. Not as bad as the Megs W-4000 though.
  1. Replies: 4
    Last Post: 05-28-2020, 09:24 AM
  2. Rupes LHR15 Mark2 & Ibrid Nano - Issues Concerns and Observations
    By Perfectionista in forum RUPES BigFoot Oribital Polishers
    Last Post: 01-28-2020, 07:37 PM
  3. rupes original bigfoot 15 vs griots boss 15
    Last Post: 01-04-2017, 05:43 PM
  4. Rupes microfiber pads
    By aburgeson in forum Product Reviews
    Last Post: 08-11-2014, 02:19 PM
  5. Rupes Microfiber Cutting Disc with Rupes Zephir Gloss Coarse Gel Compound
    Last Post: 07-19-2014, 05:30 PM
