Results 11 to 20 of 22
    Nov 2009
    Pasadena, CA
    12,615
    Re: Tried my 2 new polishers today
    The only thing is there’s no turning back once you do that..
    Is that a mini 3” polisher?
    True, but I would never turn back. I have all of my shrouds trimmed. It's a waxshine 12mm 5" polisher.
    '03 Corvette Z06
    Jun 2013
    Montreal, Quebec
    3,996
    Have you checked with Griot's if they allow this under warranty? I would not want to cut the shroud, have the machine die down the road and be denied a replacement because I cut the shroud.
  3. #13
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    You can get the cut straighter, but I didn’t care. The bolt is now attached 100% to the spindle like it should be, yet the BP still spins freely as if there was a washer in between.
    One guy was taping sand paper on his plate to mow it down. He used to get really pissed people weren't doing it his way...
  4. #14
    May 2013
    Rochester Hills, Mi
    6,016
    Quote Originally Posted by Calendyr View Post
    If you used is constantly with no washer, it would wear itself out anyway.
  5. #15
    Nov 2009
    Pasadena, CA
    12,615
    G15 lacks torque, IMO. G21 has more torque, based on momentum alone. Never tried the 10X.
    '03 Corvette Z06
  6. #16
    Sep 2017
    Sweden
    3,022
    The 5" backing plate I bought to the 21mm longthrow polisher I have. Is made so the shroud don't touch it. So the washer mod was not necessary to do or trim the shroud down.
    Test it out as Eldo suggest without the washer on. And see if that's helps to the vibration.
    Is it a big difference from the BOSS pads and LC HDO pads in weights and hight? That could set it off to more vibrations too.
  7. #17
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Good point. The BOSS pads are among the thinnest I've ever used.
  8. #18
    Mar 2017
    Southeastern PA
    2,480
    I’ve only used my G15 with LC ThinPros so far. Very smooth IMO. Way better than my PC 7424 with the same pads. I have the washer mod done with the washer that came with the polisher.
    Bruno Soares
  9. #19
    Jun 2013
    Montreal, Quebec
    3,996
    Possible. I will try my LC ThinPro next time around before removing the washer to see if it removes the vibration.
  10. #20
    Super Member ScottH's Avatar
    Nov 2015
    Northern NJ
    895
    I have several G15's and all are single-washer mod, and when used with LC ThinPro's, LC CCS pads and BOSS pads - ultra smooth. I find it slightly less smooth with Thicker pads but no where near what the OP indicated. I can (and have) used them all day without any issues at all. I love their smoothness.
    ScottH
  11. Likes PaulMys liked this post
  1. WW15 sale today, but confusing about polishers
    By Thomkirby in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 09-09-2018, 12:45 PM
  2. Polishers
    By Lumorales1975 in forum Auto Detailing 101
    Last Post: 05-11-2018, 03:56 PM
  3. Video: Orbital Stroke Comparison - RUPES Bigfoot Polishers vs Basic DA Polishers
    Last Post: 02-11-2013, 01:43 PM
  4. DA Polishers
    By mark58 in forum Auto Detailing 101
    Last Post: 01-10-2012, 09:37 PM
