» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Senior Member osiapstndp's Avatar
    Apr 2016
    271
    Re: Lake Country Hybrid Force Pads on Rupes Mille ?
    Quote Originally Posted by TTQ B4U View Post
    I'll post my thoughts this weekend as mine should be here Friday.
    Sent from my Galaxy Note 8 using Tapatalk
    I'm looking forward to hearing about your experience. I love using my Flex 3401 and Force pads, but the 5mm orbit of the Rupes tool has me thinking.
  2. Likes TTQ B4U liked this post
  3. #12
    Senior Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    3,055
    Quote Originally Posted by osiapstndp View Post
    are you finding the 8mm throw on the Flex is what is causing it to walk or control you a bit more?
    to me I don't find the flex bothersome at all. I love the smoothness of a the Rupes long throws and they have power but I won't buy a non forced unit any longer and don't mind the 8mm pull that it seems to have.
  4. #13
    Member
    Jul 2017
    El Mirage, AZ
    60
    Please let me know how you like the Mille on Friday. I'm in the same boat as you where I have the Hybrid Force pads and I'd rather not replace the entire setup if I can use it with the Mille.
  5. Likes TTQ B4U liked this post
  6. #14
    Apr 2016
    271
    Sometimes it feels like the 8mm throw is too much. On roofs, for example, it pulls and pushes on its own when I can't put enough weight on the head of the machine. The roof is where I find the Flex is most uncomfortable, but on long hoods it's sometimes not a fun experience either. It seems like the 8mm throw is a culprit.
    It isn't *that* bad though and I've never completed a car and thought I felt "beat up" by the machine, but then again I've never used free spinning tools from start to completion because I always go back to the 3401 or to a Flex rotary for cutting. Even when I try to only use my Griot's G15 on flat panels I end up ditching it. On a lot of the factory clear I've worked on the 3401 has finished down beautifully with M205 and a white or black Hybrid or Force pad. Even on super soft aftermarket clear I've been able to finish it with the 3401 and some finesse.
  7. #15
    Sep 2017
    NH
    i currently have 95% lake country pads, gg6 and aios. meg stuff for paint correction and this exact thread pushed me to preorder the mille instead of order the 3401. I decided to preorder the mille standard kit because i will be using this tool for extended periods of time not only on cars, but boats. I'm all for a work out but i also want to adapt the rupes system eventually after my pads and product deplete. My 1988 23' sea ray sorrento will be the first Vitim with the rupes which is heavily oxidized.
  8. #16
    Jan 2016
    Central Ohio
    3,055
    Quote Originally Posted by Kiddersdetailing View Post
    right on! I'm excited to get mine tomorrow. My first detail is an easier new car prep and coating though but it will still serve as a good test vehicle. Looking forward to seeing the follow up posts from others here.
  9. #17
    Senior Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,689
    I see you pulled the trigger. I'm interested in seeing how to see how those pads work on it. I do like thicker pads on some vehicles. I've gone to 90% Boss pads for regular compounding and polishing. I do have yellow Rupes pads. That's one of my favorite pads.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  10. #18
    Senior Member fly07sti's Avatar
    Sep 2013
    Bay Area
    1,878
    One thing I can’t seem to quite understand is why the Mille pads are so thin. I bought Mille pads to use on my Duetto and love em.
  1. Lake Country Force Hybrid Foam Pads New & Improved!
    By Bryan@Autogeek in forum New Car Care Products
    Last Post: 02-06-2018, 08:48 AM
  2. Replies: 22
    Last Post: 08-23-2017, 11:05 PM
  3. Detailing a beater! - 1972 Buick Riviera Boattail - Review: Lake Country Force Hybrid Foam Pads
    By Mike Phillips in forum 2018 Product Reviews by Mike Phillips
    Last Post: 04-21-2017, 06:41 AM
  4. Lake Country Force Hybrid Pads *New & Improved*
    By VISITOR in forum Wool & Foam Buffing Pads
    Last Post: 04-12-2017, 07:35 PM
  5. Lake Country Force Pads at AG?
    By roguegeek in forum Wool & Foam Buffing Pads
    Last Post: 03-11-2017, 04:36 AM
» June 2018
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
