Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 58
  1. #31
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Have a problem with a RUPES polisher or product?
    Quote Originally Posted by DaveT435 View Post
    I was kind of disappointed that after the first major repair and having the same problem when I got it back with the same problem they didn't offer to replace it. Flex replaced a machine that hadn't actually gone bad yet because they were aware of some problems with the early XFE-7s. Any manufactured product your going to have a certain number of bad units. I'm sure Rupes is a pretty low percentage, I just happened to get one. Obviously it won't stop me from buying Rupes, but if it's a tough decision between Rupes and another machine that may sway my decision.
    There is a 90 day warranty when they rebuild. I'm not sure with repairs, may only be until the original warranty expires.
    True enough. But in my opinion, this forum is full of 1%ers
    If the 1%ers are posting problem after problem with the Rupes and no guarantee of satisfactory service/replacement, that would be a huge turn off to me if I were reading/deciding on an investment of a polisher. It's as simple as that. Just a future cost thing with me.
  2. #32
    Nov 2016
    45
    I was thinking that Rupes can not make such a mistake but obviously wrong.
    So, now I come home and inspect just recived new rotary pads.
    I have Rupes Rotary backing plates - also new products with codes 992.500, 992.600 and 992.650 which have center hole.
    Main problem is with 9.BR180 pads (blue, yellow and white) and that is center hole on the pads is not in the center of the pad and it is not possible to center pads on backing plate as it should be if the hole on the pad is in centre.
    Obviously it is possible to center pad to backing plate but in that case holes does not match.
    The problem is in 9.BR150 and 9.BR200 pads also but little bit less than on 9.BR180 pads.
    Really interested what Rupes have to say and if they replace faulty ones as those are not so cheap ones to make such a mistake.
  3. #33
    Nov 2015
    Los Angeles, California
    13,729
    Quote Originally Posted by ARTB155 View Post
    Pics?
  4. #34
    Nov 2016
    45
  5. #35
    Nov 2015
    13,729
    But measure the pad from the velcro side... And measure your backing plate too. That way we can see how it’s off.
  6. #36
    Nov 2016
    45
    It is off for about 5 mm if aligned hole to hole (pad hole to backing plate hole).
  7. #37
    Nov 2015
    13,729
    5mm? You’re talking about just over 1/8th of an inch? That’s nothing.
    No manufacturer makes the pads the exact size of the backing plates.
    Eyeball it. It’s easy. It’s normL. Everyone deals with that minimal slight difference in size between the pad and the backing plate. It’s not a problem.
  8. #38
    Nov 2016
    45
    Obviously we do not understand each other.
    I am completely aware what you want to say but that is not point.
    I just ask why pad center hole is not in the center of the pad than out of center for about 10 mm or little bit less than 1/2 inch???
  9. #39
    Nov 2015
    13,729
    Ok ok, I see what you’re trying to say... The reason I didn’t get what you were saying before is because I can’t see your pictures full size, when I try to click on them it asks me if I want to follow them into a gallery and I don’t want to follow that link so I can only see a very small thumbnail from my view and therefore wasn’t able to see the details you were talking about. I still can’t, but I now know what you’re talking about.
  10. #40
    Nov 2016
    45
    No problem...now it is clear what I want to ask and it will be very nice to hear some words from Rupes if they follow this forum.
    Fortunatelly there is a batch number printed on the pads and it seems that all pads from batch #RO518 have the same problem.
    All my pads except one (and that one is OK) are from batch #RO518
  1. Replies: 2
    Last Post: 08-20-2018, 08:00 AM
  2. Rupes polisher, Rupes pads, non Rupes polish
    By joleyred in forum Auto Detailing 101
    Last Post: 05-27-2018, 10:18 PM
  3. rupes pads on non-rupes polisher?
    By JCDetails in forum Auto Detailing 101
    Last Post: 08-07-2017, 07:51 PM
  4. How do I prime a Rupes Foam Pad on a Rupes Polisher?
    Last Post: 01-10-2017, 11:26 AM
  5. Replies: 6
    Last Post: 05-02-2016, 10:08 AM
