Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Super Member ronkh57's Avatar
    Aug 2009
    3,392
    Re: Differences between Rupes Nano Long Neck and Short Neck?
    I went with long neck for vents like this
    and door frames
    Super Member Crispy's Avatar
    Jun 2013
    779
    I bought the short neck because it was on sale, but my thoughts are the long neck will get in spots the short neck will not but not vice versa.
  3. #13
    Super Member AZ Mike's Avatar
    Jan 2014
    Phoenix, Arizona
    1,128
    For those of you that have them, what are your thoughts after using them?
    AZ Mike aka "Repeat"
  4. #14
    Jun 2013
    779
    Update on the short neck. Very easy to use so far and control is an issue with the rotary tool. Using the blue pad it tends to try to migrate even at speed 1. Two hands to keep on course. Long neck would be even harder.
  5. #15
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Thanks for the update on the Nano. I'm still riding the fence whether to get the long neck or the short neck. I might just go with the short neck for better maneuverability.
  6. #16
    Dec 2010
    91
    A update on the post - I went with the long neck eventually. Some pictures of my new toy,
    I like to keep things organised so all batteries is labelled.
    i drew a small marking to help me quickly align the battery to the tools. I am a lazy person so I tend to do things that makes my job easier.
    I like to keep this tool close to me so that I can easily reach out to it to remove heavier defects after a standard polishing cycle. The portability and weight of this tool makes this possible.
    Tools in action..
    Having use the nano for a month plus now, rotary feature is currently one of my favorite. You get so much more control compared to attaching a 1 inch backing plate on a heavier rotary. Having use a good number of battery power tool, I find the Nano battery life pretty impressive.
    Some not so good points- the trigger imo need a locking mechanism. Without this feature, I am basically force to hold the tool in a certain way. There was once I need to buff along the car roof which had a rack on, and with the rack in the way, I had to maneuver parallel to the rack and it was really a difficult position to keep the trigger engage. In addition, the body where we grip the tool tend to get warm so locking mechanism also allow us to change position as it gets warm. The orbital works well on flat area but 12mm orbit is tough to keep it spinning on tight curves even with little pressure. 3mm orbit lack quite abit of torque too.
    Having said that, overall no regrets for this tool. If I am given a second chance, i will definitely buy it again. It has provided me with value that no other tools did- portable, lightweight, surgical buffing etc.
  7. #17
    Aug 2016
    48
    I wonder if a thick o-ring can be used as a trigger lock, roll it up to hold the trigger down, and roll it down to release... anyone get what I am saying?
    I don't have a nano to test this myself, but if anyone wants to send me one.... :P
    It's high on my list right now, not higher than a ptg, but near that high.
  8. #18
    Jun 2013
    779
    I'm only doing my own car and so far no issues. I really use rotary too mostly. You can only use it with the 1 inch pads but no problems (I did try with the 2 " and sling city). As far as the trigger lock my technique puts the switch in my palm which Rupes intended. Precision polishing requires precision techniques.
  1. Rupes Bigfoot ibrid nano long or short neck
    By patricemougeot in forum RUPES BigFoot Oribital Polishers
    Last Post: 07-04-2018, 01:44 PM
  2. Rupes Bigfoot Nano iBrid Short or Long Neck
    By theamcguy in forum RUPES BigFoot Oribital Polishers
    Last Post: 09-09-2017, 07:03 PM
  3. Video: RUPES Bigfoot Nano iBrid Short & Long Neck Kits
    Last Post: 08-30-2017, 06:02 PM
  4. Replies: 4
    Last Post: 07-25-2017, 05:02 AM
  5. Replies: 25
    Last Post: 01-14-2017, 02:43 AM
