Results 11 to 20 of 28
    Super Member Dylan@RUPES's Avatar
    Oct 2015
    215
    Re: Rupes LHR 15 Mark II: What is the best cutting MF pad?
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Quote Originally Posted by Dylan@RUPES View Post
    I was using these before I even considered buying a machine from Rupes.
  3. #13
    Oct 2012
    202
    Meguiars Microfiber Cutting pads are awesome. I use them on my Rupes 21. For my 15 I like the the rupes pads and LC orbital pads. I don't have any Megs Microfiber pads for my 15 but I'm sure they work just as good as in the 21".
  4. #14
    Nov 2009
    Pasadena, CA
    12,615
    Meguiars MF cutting pads or CarPro MF cutting pads.
    Ironically, Rupes MF pads would be my last choice. They cut and finish good, but don't contour well.
    '03 Corvette Z06
  5. #15
    In time out
    May 2016
    745
    I use either the Meguairs with a made to fit backing plate or the blue rupes micro fiber. Both cut extremely well.
  6. #16
    Aug 2014
    Brazil
    492
    Megs DMC5 & DMC6 microfiber cutting pads do have a foam interface.
    Indeed it does, but it is thinner if you compare to the CarPro MF pads
    Rupes LHR 15 Mark II: What is the best cutting MF pad?-img_6142-jpg
    DMC5 compared to CarPro MF pad
    Rupes LHR 15 Mark II: What is the best cutting MF pad?-img_6140-jpg
    DMX5 compared to CarPro MF pad
    This is why I use foam interface sometimes on Meg's MF pads, especially on curved panels.
    Best regards
  7. #17
    Dec 2009
    Chula Vista, CA
    34
    I'm assuming a thinner foam interface would be better for cutting and a pad with a thicker foam interface would be better for finishing. Does this make sense? Your thoughts?
    If this is the case, should I just stick to all foam finishing pads?
  8. #18
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Quote Originally Posted by CalSun Detail View Post
    That is correct however when it comes to finishing,foam leaves a better finish.
  9. #19
    Super Member BadgerRivFan's Avatar
    Aug 2015
    Mt. Horeb, WI
    884
    Quote Originally Posted by lane5515 View Post
    5.5" GG Boss Microfiber pads + Rupes 15MKII paired with GG Fast Correcting Cream = defect killer and to most LSP ready. I've also used the Megs 5.5" MF cutting pads and they work good but not nearly as user friendly as the GG.
    +1 on lane5515's comments.
    I don't own the 15 MK II, but I've had great success using the Griots Boss 5.5" MF pads with Griots Boss Fast Correcting Cream with my Flex 3401.
    They're made for use with long throw DA's so should be a fine combo to try with the new Rupes machines.
    ​Al Schmidt
    "Adventure, is a car called Riviera..."
  10. #20
    Nov 2015
    Los Angeles, California
    13,729
    Quote Originally Posted by RPM_BR View Post
    Best regards
    Gotcha👍🏽
  1. Rupes LHR15 Mark II, for cutting?
    By braga in forum RUPES BigFoot Oribital Polishers
    Last Post: 03-17-2019, 10:21 PM
  2. RUPES Giveaway! Autographed RUPES 21 Mark II Up For Grabs!
    Last Post: 09-14-2016, 03:13 PM
  3. Recommended pads for Rupes mark ll and Rupes mini
    By Elger in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 09:32 AM
  4. Replies: 29
    Last Post: 05-21-2016, 07:46 AM
  5. Rupes Mark II , Mark ii NICE!
    By SonOfOC in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-25-2015, 04:20 PM
