Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Regular Member 11B250's Avatar
    Feb 2015
    Palm Beach County, FL
    155
    Re: Revisited Rupes UHS system
    Quote Originally Posted by Todd@RUPES View Post
    It really will depend on the paint surface you are polishing (and other variables).
    On most paints, I find that UHS (pad/polish) will have a slight advantage of cutting power of the original Quarz and slightly less than the new Quarz. In terms of finish, I find that UHS will finish better than either version of Quarz.
    On harder, high-solid scratch-resistant clear coats, UHS will suffer less than other polishing systems. On PPG's cremaclear, for example, the UHS can out perform even the Zephir/blue foam in cutting ability while generating a flawless finish.
    So how will the UHS system work with a non rupes polisher? (let's say forced rotation) Just curious...
    and I hear this ceramiclear alot lately. Wasn't this a clearcoat that was used for a very short time on mercedes? (The paint code is supposed to hace a C or something on the plate) my Cl550 doesn't have that C to denote ceramiclear?
    Super Member Dylan@RUPES's Avatar
    Oct 2015
    215
    Ceramic clear or high solids clear... its really just boils down to really hard clear coat (concrete hard). The UHS system was designed to address those paint systems, but honestly it works like a charm on everything. I use it almost exclusively on my toyota 4runner and the paint on that thing is average to soft.
    As far as the use on a gear driven tool... not sure. I honestly haven't tried it, but if you do let us know how it goes.
  3. #13
    May 2015
    Maybe you've had a chance by now to try it on the new Mille 900E? I have quite a few UHS pads and noticed there are new Rupes Mille polish formulas.
    Quote Originally Posted by Dylan@RUPES View Post
  1. Rupes revisited
    By lj993 in forum Product Reviews
    Last Post: 04-03-2020, 12:47 PM
  2. Detail Class - RUPES BigFoot aka The RUPES Paint Correction System
    Last Post: 04-09-2018, 04:06 PM
  3. Revisited Rupes Diamond Ultra Fine Polish
    By WRAPT C5Z06 in forum Product Reviews
    Last Post: 05-25-2017, 12:24 PM
  4. What do you use as LSP after using rupes system?
    By TMQ in forum Auto Detailing 101
    Last Post: 03-07-2017, 11:55 AM
  5. Rupes UHS system is on it's way!!!
    By Matt@Revive in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-28-2014, 09:05 PM
