Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Super Member mavin's Avatar
    Apr 2013
    Ann Arbor
    377
    Post Re: More DA or rotary... Please!
    Quote Originally Posted by hernandez.art13 View Post
    If the DA does not correct whatever you are trying to fix, my advice to you is either call a Real Local Detailer or just live with it, but do not use wet sand paper on your car.
    It requires skill/technique to wet sand one's car.
    And if you burn through your paint, it will need to be repainted, which is costly.
    Good Luck!
    (Pictures)
    I could have sworn last week you were telling everyone to wet sand their cars :P
    Super Member Flash Gordon's Avatar
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Quote Originally Posted by mavin View Post
    That was probally me. I like to wetsand everything I can get my grubby lil hands on
    No, wait. I wasn't here last week. Musta been Mr Hernandez
  3. #13
    Super Member hernandez.art13's Avatar
    Apr 2013
    6,958
    I ONLY feel comfortable wet sanding car's that have been freshly painted.
    I tend to forget that a lot of people here work on DD. I on the other hand, mostly worked on freshly painted cars. So wet sanding was necessary to remove the orange peel.
    So everyone listen up... Do not wet sand your car, without knowledge of knowing what you are doing! because without skill/technique you are very likely to burn through the paint. Only way "I" know how to fix this is to repaint.
    I kind like "Mr. Hernandez Detailing" might be my new business name hahaha jk :P
  4. #14
    Apr 2013
    6,958
    Quote Originally Posted by Flash Gordon View Post
    You Flash Gordon do amazing work with your 800 grit lol, way way to advanced for my paint correction skills lol
  5. #15
    May 2013
    Hmmm, ok. avoid the paper.
    Since the DA has limited aggression I was thinking of doing this by hand on limited areas, such as where my door was keyed, bumper bumped and the trunk scratched - not sanding the entire car. Probably 2000 grit followed by 2500 or 3000 - by hand so I could be carful, then try and smooth it with the DA. Responding to the machine questions, is the machine sandpapering easier or harder to get out, and what kind of machine?
    One more thought - is there something that would fill such scratches effectively?
    Thanks again!
  6. #16
    Super Member rmagnus's Avatar
    May 2011
    SoCal
    1,446
    Quote Originally Posted by CCVirginia View Post
    Thanks again!
    If you machine sand it's more uniform and easier to remove the sanding mark. Using a DA and MF pads you ca get 3000 grit marks out pretty easy. It will even handle 2500 grit ok. No question a rotary and wool pads are the best solution but nothing wrong with MF pads if you have a DA. I would not recommend sanding unless you have the right tools.
    Get experience in a junk yard panel might be the best $50 you've ever spent. You really must have a paint thickness gauge.
    Semper Fi
    Ralph
  7. #17
    May 2013
    First, thanks for all the advise! I listened to some, but not all of it. This is what I used:
    I washed with Optimum car wash and then used Optimum eraser (aggressive). For correction I used Meguiar's Micro fiber correction system (MFC - $68) with 6 inch pads and a Harbor Freight Dual Action (HF-DA - $48). To get out the worst scratches I also used 2000 or 2500 wet sandpaper by hand (finger).
    The car is a '07 Camery Hybrid Desert Sand (4q2) - it had some bad scratches and chips, all over and in odd places. I used AutomotiveTouchup on the chips & bad scrapes. A detailer told me a pro job could run $1k due to the issues!
    Result: The car look great, it has a deep shine and most (but not all) of the scratches are out or almost invisible. The touchup paint didn't match well and I am working with them for a better match, I may get the spray for 2 bad scrapes (through the paint). My wife can't believe how good it looks and wants her car to be next.
    Experience: I was warned about sanding but mostly got away with it. The MFC could not get medium to severe scratches out so I pre-sanded those areas, very carefully, by hand. In some cases I left just a bit of scratch for the MFC to finish off. The MFC was easily able to take out the haze from the sanding with 2000 or 2500 grit (wet). While I tried to be conservative and not expect to get deep scratches out completely, I did go to far in one small spot and sanded through the clear-coat, I may fix if I can get the touchup right but it is not a big problem and may be best to leave it alone. For my case I think the targeted sanding was the right choice.
    The MFC specified specific speeds and medium then light pressure. The HF-DA would stop spinning with, what I thought was, light pressure. I had to turn the speed up to apply any pressure and keep it spinning. What is medium? - I was thinking about 10-12lbs. I don't have DA experience to know what to expect. So, the speed and pressure was a total guess but it seemed to work. I suspect the more expensive DA's don't need as much manual control of the speed setting but for my occasional use this worked out and was great for the price.
    I would highly recommend the MFC, it took the car from scratched and dull to excellent, it has a mirror shine. It was easy to use and didn't seem in danger of damaging the paint. It is a 2 step process and does take some time. I don't know how well it will last. I would have used the 5 inch pads but the kit with the 6 inch pads cost me $25 less considering shipping (due to amazon prime).
    I do have a question, how aggressive is the 2nd pass - microfiber correction finishing wax? Should this be used for follow-up care or is it to aggressive? Or, is it just a glaze/sealant? I also have a new car with Opti-coat and am wondering if it would be good to shine that up or would it remove the Opti-coat? I am also considering Meg #21, Wolfgang deep gloss paint sealant & Klasse high gloss sealant glaze. What do people use after paint correction that lasts and keeps the shine?
  1. Replies: 23
    Last Post: 01-23-2019, 04:45 PM
  2. Replies: 2
    Last Post: 08-20-2018, 08:00 AM
  3. The Flex PE14 Rotary Polisher - The rotary I grab first...
    Last Post: 09-08-2015, 11:48 AM
  4. new to rotary polishing..no rotary polisher..
    By Qusai in forum Auto Detailing 101
    Last Post: 10-24-2012, 04:59 PM
  5. Birds vs Rotary (New guy with a Rotary)
    By ANeat in forum Show N' Shine
    Last Post: 11-21-2010, 11:52 PM
