Re: Looking for a polisher...
I've used the Makita BO6040 a few times before it was permanently borrowed....
At the time I didn't much care for either mode. I first tested it out while buffing out this truck,
Custom Classic Trucks Magazine: 1956 Ford F-100 America's Most Beautiful F-100
Because it was the first time I had used the BO6040, and it didn't feel comfortable in either mode, and because the truck was important I put the tool down and used a rotary buffer to knock out all the heavy swirls and then finished out with a DA Polisher.
It's not generally a good idea, nor my practice to learn how to use a new-to-me tool on something that's important like a black show truck. I always say,
"Don't learn to use a rotary buffer on a black Viper"
Not that a person can't learn to use a rotary buffer on a black Viper but it's a better idea to learn how to use a rotary buffer, or any type of tool on something that's not important to you, like a beater, a panel off a car or even a daily driver grocery getter type vehicle. Then once you get comfortable with the tool then go for the black Viper or fill-in-the-blank.
I drove from Apple Valley, California to Escondido, California, (approximately 130 miles one way), which was where the car was located and only took the tool along to test it out. After buffing half the hood and getting a feel for the tool I chose to stop using it and switch to tools I was comfortable and already proficient with.
Shortly after that detail project the tool was stolen and never replaced so I would want more time behind it before forming an opinion.
The Flex 3401 is specifically built for paint polishing, it's not a multi-purpose tool like a DA Polisher or a Rotary Buffer and it has a strong loyal following and a time-proven quality and performance history.
Here's some more information about Flex quality from the President of Flex Power Tools North America from a meeting I had with Bob Eichelberg just a few months ago when he stopped by our facilities...
Rotary Buffer Talk with Bob Eichelberg from Flex Tools
Bob Eichelberg, the President of Flex Power Tools North America, stopped by Autogeek today for a meeting and after his meeting I asked him if he had some time to talk shop about rotary buffers and he politely said "yes"
Yesterday I had all the rotary buffers out to show comparative size for this thread...
So while all the rotary buffers were still out we spent some time talking about some of the differences between Flex power tools and the others you see on the work bench.
One of the things we did was one-by-one, turn each rotary buffer on, set the RPM to the lowest setting and then listen to each one as it was running.
Bob pointed out the lack of grinding noise with the Flex PE14, so I asked him why the difference?
He said the noise comes from the gears as they mesh together while the tool is running. The gears used in Flex power tools, (all their tools), are each hand ground by machine and then heat treated to strict tolerances. These extra steps,
- Reduce noise so the tool runs quieter
- Reduce wear-n-tear for increased working life
He also pointed out that Flex Polishers are designed and engineered specifically for automotive paint polishing instead of using a Global Manufacturing Process, which means the tools are designed for multiple applications, such as,
- Steel grinding, sanding and cutting
- Concrete grinding and cutting
- Polishing paint
The Global Manufacturing Process is a one-size fits all approach so that one tool design can be marketed into multiple industries.
Bob said this is key difference that separates Flex Power Tools from others plus all Flex power tools are designed and manufactured in Germany with a 90 year reputation of German engineering quality.
I also asked him about using the PE14 in the same manner that a person would use a full-size rotary buffer, that is with a full size wool pad doing heavy cutting all day long and he said "yes".
Thought I would share our shop talk from today with all my forum friends and to be fair and balanced, anytime a representative, or even the President of any of the other companies for the tools we carry wants to stop by and talk shop the door is always open.
Excellent advice on the Flex. I must admit I do not own one yet but when I pull the trigger (no pun intended) I will get a Flex for the reasons stated (purpose built and German engineering).
Mike P. I did notice one thing that seems somewhat of an oxy-moron while reading the above article. Can you give me a better understanding of this phrase, "...are each hand ground by machine and then..."?
Ha ha...
I asked Bob the same question!
That means each set of gears are ground individually by machine with a human controlling the machine. At least that's how I think he explained it. The big picture idea is the gears and possibly other components are not stamped-out in a high production process.
I'll find out more and let you know.
The most eye-opening, or actually ear-opening, was the sound each of the tools made when you run them side-by-side at low RPM and with the Flex it's smooth and quite and with the other tools you can hear the growling of the gears.
Good question...
Why didn't you use the makita with the forced rotation mode turned off,and continue on testing out this tool...this is not making sense to me considering your lifes experience!
Checkmate!
Dan
Checkmate!
Dan
Did you not read his answer:
I did read his answer!
And I came to the conclusion a da is a da and with all his experience he out of people could have had finished out this truck with the makita in da mode with out even blinking twice in fact I think one would even look forward in doing so IMOP its not a big deal,but to you..must be so....
It's not big deal...
It was just my preference at the time...
Last Post: 12-04-2019, 07:35 PM
Last Post: 04-08-2018, 09:52 PM
By Red Lehr in forum Auto Detailing 101
Last Post: 09-25-2017, 04:47 AM
By Andre in forum Off-Topic
Last Post: 02-04-2016, 12:44 PM
By torque1989 in forum Ask your detailing questions!
Last Post: 07-01-2011, 10:11 AM
25 | 26 | 27 | 28 | 29 |
