Only Using Wool Pads For Rotary
I have only used wool pads for heavy compounding and was wanting to try them out for polishing and finishing. Has anyone else used wool for light polishing instead of foam pads? I was thinking about trying the edge wool double sided polishing pads but i never see anyone use them in the forums so there is no good reviews that I can find!
Thanks!
Re: Only Using Wool Pads For Rotary
Thanks!
Every tool has its intended purpose. Just like you can't expect a blue or gray LCC pad to do any correction, you would be remiss to attempt to use a wool pad for polishing or jeweling. A white or green LCC foam pad after wool with any good polish will eliminate any compounding marks and leave the finish in great condition.
Hello Richy i wasnt talking about a heavy cut wool compounding pad i was wondering about the edge wool polishing pads to use with polishes not compounds....I was wondering who has tried these pads instead of CCS or foam for polishing or finishing.
Green Light Cut 40% Wool, 20% Acrylic, 40% Rayon Pad
The green pad produces beautiful results with one step cleaner polishes. It has enough cut for cleaning the removing very light imperfections on paints that are in overall good condition.
Blue Finishing 70% Acrylic, 30% Wool Pad
Use the blue pad for general polishing and gloss-enhancement. The blue pad can be used with any finishing polish to bring out a fine luster on any finish.
White Ultrafine Finishing Australian Lambswool Pad
One of a kind! This silky 100% lambswool pad adds a mirror-like glow to the paint. Use the baby-soft lambswool pad with a glaze or ultrafine finishing polish. This should be the last pad that touches your paint before wax application.
Thanks!
Wool finishing pads work great as a follow-up to a wool cutting pad to refine the swirls left by a wool cutting pad to more shallow swirls left by the finer fibers of a wool finishing or polishing pad.
The problem you run into is because wool pads are made of individual fibers, each fiber can cut the paint and this leaves buffer swirls in paint.
That said, for some work or some detailers, a 100% swirl free finish may not be their goal, so for them a wool polishing pad is a great follow-up pad after a wool cutting pad.
You could also use a foam pad after the wool finishing pad to remove the swirls left by the wool fibers. Just depends upon your goal and now many steps you want to do.
By oneheadlite in forum Rotary Buffers
Last Post: 09-05-2020, 08:50 AM
Last Post: 08-28-2020, 05:29 PM
By mwoywod in forum Ask your detailing questions!
Last Post: 11-02-2017, 08:31 PM
By sansa in forum Auto Detailing 101
Last Post: 02-24-2016, 12:48 PM
By BlackRocks in forum New Car Care Products
Last Post: 06-16-2006, 08:44 PM
