hey guys. I have an SSR here at my place that i have as long as i want. It has some v
hey guys. I have an SSR here at my place that i have as long as i want. It has some very heavy swirling, that i removed using IP and 5.5" LCC White pad on my Rotary.
The IP left some very heavy swirls on the truck, which is to be expected, and i was planning on polishing them out with Nano(grey pad) and a 85rd(blue pad)..
However, after that, the Halograming is MUCH better, but there is still evidence of it being there??? finish polishing with nano and 85rd are being done at about 1200 rpm
I even tried IP on a green lcc pad then the nano 85rd after and it still remains?????
i need some serious advice...im stuck
Im gonna toss this on Autopia also to try and get soem asnwers fast...please help
Re: hey guys. I have an SSR here at my place that i have as long as i want. It has so
I haven't had that problem with IP or SIP ever, even when using them with an orange pad, but then again I usually use them with a UDM and have only used SIP once with my rotary, but still did not have that problem. I'm honestly a bit stumped. The only thing I could think of would be to finish with nano or 85 on even lower speeds.
2003 Lancer Evolution VIII
Buschur TBE, Apex'i intake, Hallman Pro RX MBC, Evo 9 and Forge DV's, Swift Sport Machs, FP Green, ETS 3.5 FMIC and piping, Megan coated mani, Megan O2 housing,injectors, Walbro 255, HKS 272's, ARP headstuds, and Cosworth headgasket
381 AWHP, 91 octane and 25psi
272 AWHP (DynoDynamics, 312AWHP DynoJet) 93 oct
252 AWHP (DynoDynamics, 292AWHP Dynojet) 91 oct
^^^Old numbers
SELF BANNED
Start over, use your M105 with a wool pad and then work your way back up to a finish polish. Remember it might take several times with the medium polishes after the 105 to get correct than finish up with your finishing polish on a finishing pad.
this truck didnt need m105 tho, with ip it removed the defects in the paint...
why is the IP with a white foam pad leaving this heavy swirling???
im jsut sorta confused there on why id go to m105?
maybe the IP is not strong enough to remove what you w ant
You said it left swirls in the paint. Did it leave any type of swirls or only holograms? If there were only holograms the paint should be completely defect free minus the haziness. If not then the IP wasn't strong enough and you need to go with what killr said.
SELF BANNED
Whos Killr in this thread?
Looks like it turned out pretty good !!!!!
Ron !!!!!
By 32ValveRom in forum Auto Detailing 101
Last Post: 10-13-2012, 11:27 PM
By Jons6.7 in forum Off-Topic
Last Post: 07-13-2011, 03:39 PM
By drastic_detail in forum Off-Topic
Last Post: 09-22-2009, 09:27 PM
By trhland in forum Auto Detailing 101
Last Post: 10-15-2007, 04:32 AM
By Thejoyofdriving in forum Auto Detailing 101
Last Post: 09-21-2007, 06:48 PM
