» Detailing Classes
Page 7 of 7 FirstFirst 1234567
Results 61 to 69 of 69
  1. #61
    Senior Member alko's Avatar
    May 2011
    4,342
    Re: Help: Rotary Buffer Use
    This is an old thread that I'm reviving, as I see alot of folks, like myself, are getting into rotary polishers. Justin posted some good links...they're great reads and have some very helpful tips.
    Quote Originally Posted by justin_murphy View Post
    This is the best guide I've found. I too am in the process of learning the rotary.
    A Guide To Rotary Polishing - Detailing World
    Here's another.......
    "Polish until the residue goes clear" - Pictorial Explanation - Detailing World
    Alex
    ...."Do the right thing...even when no one is looking"
  2. #62
    Senior Member Vegas Transplant's Avatar
    Oct 2011
    Left Lane...Hammer Down
    4,448
    Thank you alko.
    VT
    Quote Originally Posted by glen e View Post
  3. #63
    Senior Member Rix6's Avatar
    Dec 2011
    Central Coast, CA
    464
  4. #64
    Senior Member Porsche Pilot's Avatar
    Jun 2010
    Florida
    1,750
    Excellent post Alex!
  5. #65
    May 2011
    4,342
    I just read every post on this thread and man oh man I'm so glad the OP brought this topic up. This thread is full of great information. As alot of you guys know I just picked up a Flex PE-14 and I've had mixed emotions on using it. I still don't have pads, so I still haven't used it. I've been doing alot of research ever since I purchased the machine and as soon as I read something about burning paint I get nervous to even try it. But I'm sure with alot of patience, practice, and research I'll be fine. I really appreciate everyone's advice and suggestions-from old posts to new.
    Alex
  6. #66
    Jan 2015
    Question Re: Help: Rotary Buffer Use / Should Only Distilled Water Be Spritzed On Pad?
    Quote Originally Posted by TOGWT View Post
    • Ensure a ‘wet’ polishing film is always present between your pad and the surface. Swirls are usually caused by using an aggressive polish without breaking down the diminishing abrasives properly, or you may have used too much polish or it may have dried. To remove spritz the pad with distilled water...
    Does added water really have to be distilled?
    If so, what's the reasoning behind that?
  7. #67
    Senior Member mwoywod's Avatar
    Apr 2016
    860
    Quote Originally Posted by TomBrooklyn View Post
    First, I highly doubt that there would be any discernible difference between using a spritz of tap water vs a spritz of distilled. I can't imagine that the microscopic contaminants and minerals in tap water would have any negative effect in this instance.
    Second, that was posted over 10 years ago which the pads and compounds have dramatically improved and there is FAR more lubrication in cutting compounds since that advice was posted. That said, the guy is seriously knowledgeable on the polishing process.
  8. Likes PaulMys, RSW liked this post
  9. #68
    Senior Member KirkH's Avatar
    Nov 2016
    KY
    987
    Quote Originally Posted by alko View Post
    If you are nervous about burning the paint, work on a test panel and touch it with your bare hand. Feel how hot it gets. Get used to how long it takes to heat the panel up.
    Quote Originally Posted by mwoywod View Post
    You'd be surprised how "hard" the water can be in some places. I live in an area where the water comes out of limestone caves and the water is full of minerals.
    Kirk Harrod's Mobile Detailing, Frankfort, KY on Facebook
    on Instagram: btchincamarodetailing
  10. #69
    Jan 2015
    Looking into it a little more, it looks like minerals in water could be a problem.
    How Minerals Affect the Water Supplies
  1. Rotary buffer
    By Gcleov in forum Ask Mike Phillips your detailing questions!
    Last Post: 01-20-2016, 02:35 PM
  2. Rotary Buffer
    By HoldenFlinner48 in forum Auto Detailing 101
    Last Post: 08-03-2015, 02:12 PM
  3. How to use a rotary buffer
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 02-26-2015, 09:39 AM
  4. 3M Rotary Buffer
    By jgraham37128 in forum Auto Detailing 101
    Last Post: 01-01-2014, 11:55 AM
  5. Rotary Buffer
    By Sol on fire in forum Ask Mike Phillips your detailing questions!
    Last Post: 12-26-2010, 12:03 AM
Members who have read this thread: 18
» April 2019
