Re: Help: Rotary Buffer Use
Man that is some good work. I see you got the 9227 (Makita).......it's an awesome machine.
I bet you were amazed in the time it took to do the correction. I was!
Yeah, the Makita broke down the polish fairly quick; however, I had to compound twice and then follow up with a finishing polish. I operated it at approximately 1200 - 1500 RPMs once I started to develop a technique and was surprised to find the buffer did not feel or sound as if it was going very fast. It was much gentler than anticipated. I also noticed it was much easier to operate the machine at a slight angle when compounding; is tilting the machine normal?
A little tilt to the machine (10 degrees or so) works a lot better (for me) than having a completely flat pad. Excessive tilt will only lead to buffer swirls and burns possibly.
Tilting is the key. I found that this reduces pad hop. Pad hop will always be there from what I'm told. It's just a good indicator that it's time for more polish. This is why you hack shops using only wool.......no hop, but wool will 90% time give you holograms. It's a step make to knock down the defects fast and easy. You should ALWAYS follow up wool polishing IMO.
SELF BANNED
So people that use wool are hacks and they cause buffer marks 90% of the time-and this is coming from someone that has just started using a rotary. You are way off on your statement.
Great read guys i know this was a older post ... But i got a ton of info i have been looking for on this thread ... Thanks again
what i got out of what justin said was these little hack shops that are everywhere dont use foam to finish a vehicle with. they use wool to get rid of defects fast so they can move on to the next bag of money, i mean vehicle.
he never said ONLY hacks use wool he said hacks ONLY use wool. there is a big difference where that word only is placed
SELF BANNED
My preference is different than Anthony's, I like it 100% flat all the time and do not get hop that often.
Today's sticky clear coats can give a hop like result because it's becoming gluey as it's being buffed.
Just my style I suppose, everyone's different.
Once again, it's all about preference and results.
If you get the results, who should care about your preference of techiniques?
SELF BANNED
Detailgod, you have missed my point and people on here use foam just like you stated they use wool to make a bag of money, but are using aio's.
Do you keep the pad and machine flat (perpendicular) all of the time, with foam, not wool? I keep foam pads on the surface at all times but a little tilt of the machine lets my control it better. Wool is a different animal- there is less friction so keeping the pad and machine flat (perpendicular) to the surface is no problem. This is why I am liking wool pads .
Last Post: 06-17-2021, 08:13 AM
By Gcleov in forum Ask your detailing questions!
Last Post: 01-20-2016, 02:35 PM
By HoldenFlinner48 in forum Auto Detailing 101
Last Post: 08-03-2015, 02:12 PM
By jgraham37128 in forum Auto Detailing 101
Last Post: 01-01-2014, 11:55 AM
By Sol on fire in forum Ask your detailing questions!
Last Post: 12-26-2010, 12:03 AM
25 | 26 | 27 | 28 | 29 |
