sonax perfect finish
for those that use pf how many passes are you usualy doing?it seems hard to tell if the polish is broken down sometimes-thanks
Re: sonax perfect finish
It will clear up when it breaks down.
If you do very slow passes, it will start to clear up significantly by the 2nd or 3rd pass.
I spread it at 600 rpm, then one pass at 1000, another at 1500. Then three passes in the reverse order so total 6 passes. Always use a polishing pad with it, preferably Sonax orange Foam pad or LCHT Tangerine polishing pad.
This is my experience with it.
By L Gunnar D in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-03-2018, 08:55 AM
Last Post: 02-05-2018, 05:37 PM
By zmcgovern45 in forum Auto Detailing 101
Last Post: 08-09-2014, 12:53 PM
Last Post: 05-26-2014, 01:19 AM
By Mike Phillips in forum New Car Care Products
Last Post: 06-22-2012, 08:03 AM
