Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Re: TUF SHINE - Helpful hints and FAQ's
    In the below article, I recommend using the TUFF SHINE Tire Clearcoat to seal and waterproof your tires for winter.
    How to prep your car for winter
    Here's a tip for applying TUFF SHINE Tire Clearcoat...
    swanicyouth's stellar tip for applying TUFF SHINE Tire Clearcoat
  3. #13
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    I thought this was worth adding to the thread
    Hi Kyle,
    Thank you for your email and your interest in TUF SHINE.
    One 6oz bottle will coat approx 20 normal size passenger car tires with 2 coats each. A little goes a long way.
    The most important step in our system is cleaning the tires. The Tire Clearcoat is a water based product, and will not stick to any contaminates on the tire, especially silicone residue. If this is something that you are interested in, I would suggest our Tire Shine Kit, as it contains everything needed to get started.
    Best Regards,
    Bob Curtis
    TUF SHINE Inc.
    Automotive Appearance Products
    Phone: 801-520-5570
    Fax: 801-943-2829
    Email: bcurtis@tufshine.com
  4. #14
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    I also thought this was interesting, from the Tuf Shine website.
    "PROPER PREPARATION IS THE KEY TO A LASTING FINISH!
    DO NOT CLEAN TIRES IN DIRECT SUNLIGHT OR WHEN THE TIRES AND WHEELS ARE HOT."
    Very detailed prep and application instructions that might surprise you:
    TUF SHINE Tire Clearcoat | Automotive Detailing Product
  5. #15
    May 2019
    37
    Are there any downsides to using this on plastic trim like bumpers? I used it on my Jeep’s back bumper. It looks good but not sure if there are any cons to using it there
  1. hints for oxidized aluminum wheels?
    By touchdowntodd in forum Ask your detailing questions!
    Last Post: 09-22-2013, 10:25 PM
  2. dg 105, 501; search not helpful
    By jbone in forum Auto Detailing 101
    Last Post: 06-11-2012, 12:45 PM
  3. Helpful tip
    By jimbo585 in forum Off-Topic
    Last Post: 05-30-2012, 09:05 PM
  4. cleaning upholstery hints with PC
    By spitshine1 in forum Tricks, Tips and Techniques
    Last Post: 06-10-2011, 01:11 PM
  5. Hints and Kinks
    By Quiet in forum Auto Detailing 101
    Last Post: 09-10-2007, 05:35 AM
