I have a foamaster. It works pretty well but the only issue I have is that the handle seems to stick to the point that when the handle is released, the water doesn't stop. If I let it go, it'll stop spraying water in 10-15 seconds but that's rather annoying so I end up pulling back on the handle to get it to shut off. It works, just an annoyance.
Just put a little oil on the slide mechanism. It will work like a charm after. Fixed mine.
Word thanks for the tip. The only other thing I can say is that the pin with holes in that regulates the amount of suds can get stuck easily. A pair of pliers helped a time or two but 99% of the time I can do it by hand.
