Hey Folks, Some help.
Hey folks. So I'm pretty intent on purchasing my first polisher and taking advantage of the black friday sale. I will be primarily using this on Honda vehicles with thin paint.
My question is what pads and other accessories should I be purchasing?
I've concluded so far to purchase the GG polisher because of the extra added power, M105 and M205. I've also read somewhere to buy a Menzerna product to finish after 205. Any recommendations of that?
Also I want to purchase pads for the stock 6" backing plate. What should I be considering or purchasing. I'm fairly new to machine polishing and want to start this right!
Thanks for the help and hope y'all had a great thanksgiving.
Re: Hey Folks, Some help.
Honda's have soft paint that is easily corrected. Probably don't need 105/205
I'd go with Menz SIP or Power Finish followed by 106FA or 85rd (SF4500)
I'd also get flat pads, either 7/8 in hydrotechs (tangerine and crimson -- cyan's not so good on soft paint) or LC flats (orange white black).
GG6 should be able to spin the 6.5 in pads no problem but they are a bit big. Might want to consider a 5in bp and 5.5 inch pads...
I told my wife that a husband is like a fine wine; he gets better with age. The next day, she locked me in the cellar.
~Tim
I previously owned an Acura RSX (also made by honda), i had the chance to use a paint thickness gauge on it. I found out the factory paint was very very thin. I would stay away from the 105. Its a pretty agressive product.Try some thing mid agressive like Wolfgang "total swirl remover". then a finer polish. 5 inch backin plate is great for the 5.5 inch pads which work well with the GG machine. XMT 360 is a great one step I used on my Acura. Not too agressive but leaves a great gloss behind.
I would go with Meguiar's D300, mf cutting discs, Menzerna PO85RD, Lake Country flat black pads. It wouldn't hurt to have M205 and a couple tangerine Hydro Tech pads on hand but I think the above combo will be just fine.
good advice... don't use the griots pads
Menzerna polishes are the industry leader IMO.
Or go with Lake Country CCS pads. Orange, White, Blue or Gray
I havent tried the RD85 but Richard is spot on regarding the Megs Cutting MF.
I dunno, D300 and MF cutting is the same as 105 and foam imo
You can probably get away with a one step using power finish on orange pads, maybe even hyperpolish on white...
~Tim
^ First I've heard anyone say that. But then again, what foam pad w/ M105? That's what I like about discussions, it's fun to read others experiences because you never know when you'll pick up on something.
I just got done doing a winter detail on my car, a 2010 Acura TSX. The paint, of course, is soft as heck. I used a PC7424XP with Lake Country Tangerine Hydro Tech pads. For the product(s) I used the Wolfgang Twins (Total Swirl Remover and Finishing Glaze). I used grey CCS pads to apply the Finishing Glaze. I topped that with some machine applied Collinite 915 and another product. It came out great!!!
This past summer I did a 3 stage machine polish with Sonus SFX-2 through 4. I was amazed at the results. I would recommend, for your vehicle, using the Wolfgang Twins. The pads I recommend are either the Lake Country Flats or the Hydro Techs. The Low profile techs may last you a bit longer. You just gotta make sure that you're cleaning the pads and switching them out. If you go with the Hydro Techs, I recommend getting atleast 6 of them...and yes...use all 6 while polishing. You will find that these pads do not last long. Once they get saturated they will build up heat fairly quickly, which will cause the middle of the pad to degrade. Switch them out after each panel....trust me.
Top the polish off with a great carnauba wax and you'll be ready to roll!
Alex
...."Do the right thing...even when no one is looking"
By LSNAutoDetailing in forum Customer Comments
Last Post: 02-15-2016, 01:51 AM
By Paul A. in forum Introduce Yourself
Last Post: 01-11-2012, 08:25 PM
By bigirn in forum Introduce Yourself
Last Post: 11-16-2010, 12:12 PM
By HarleyRyder in forum Introduce Yourself
Last Post: 08-30-2010, 03:05 PM
By trhland in forum Auto Detailing 101
Last Post: 09-09-2007, 02:48 PM
