My body shop here has the 3M products and are used often. However the products that we have on the shelf are the older generation that has been around for quite a few years.
As for the heavy compound from 3M, it will cut more than anything I have used. Menzerna SC300, Any of the Meguiar's compounds, etc. Sure its a bit more on the old school side of things in that you can actually feel the grit between your fingers which allows such heavy and fast defect removal. Yes it does haze up the finish its nothing that its secondary product cant remove.
I haven't tried using the 3M line with the 3401 as I always run them with the PE14. I guess I should do some playing around with them together with the 3401.
