Re: some product went bad after a year
Originally Posted by swanicyouth
Put a few clean nuts in the bottle - that will make shaking them more effective. Think of the little ball in rattle can spray paint.
peanuts or cashews? :-P
Back to the full-time grind.
Good idea. Could even use a larger ball bearing. I like the idea of using a clean nut, however there could be fine metal shavings in the threads.
Optimum polishes don't seem to have a great shelf-life, IME.
"I've seen a good quality car wash look better than some guys complete detail jobs."
Mike Phillips 10/21/09
agreed...
I agree. The Hyper compound and polish do ok, none of the others though.
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
If you are talking about metal nuts, they will rust and contaminate the product in the bottle.
Once the inner seal is removed, any solvents/carriers can evaporate away, ruining the formulation.
Maximum life comes from as little temperature change as possible. Leaving products on a carport, and in direct sunlight, will effect most products.
Invest in a carry crate and bring the products inside when not in use.
Originally Posted by paul_g
The pinnacle glassworks w/ water spot remover will separate naturally within hours... it's not bad, ... one must shake it.
I have a reminder on my iPhone to shake all my product once per month...
I tried shacking it for a while and it just seems too far gone. It seems to be way to liquefied. It should be thick right?
I wish I could bring everything inside but just have too much stuff. I need to see If I can bring in just the stuff that has a risk of going bad.
Right now it's in the carport but it's away from the sunlight.
I ran into the same problem with Pinnacle Black Label sealant. However, I keep mine in climate controlled environment and shake it at least once per month. It seems to still be very liquified and to top it off the pump blew out.
By Kamakaz1961 in forum Auto Detailing 101
Last Post: 01-01-2018, 05:14 PM
By Wmflyfisher in forum Boat & Marine Craft Detailing
Last Post: 02-01-2015, 09:27 AM
By expdetailing in forum Auto Detailing 101
Last Post: 12-15-2014, 01:55 PM
By JoeD in forum Off-Topic
Last Post: 06-09-2007, 07:43 PM
