Re: Car Pro Essence Reviewed! 6 Months of Testing by OCDetail
Originally Posted by builthatch
i understand - it says that because they can't be sure you are going to use Hyper. i've looked into it with them.
Conman does make some good points. personally i don't agree with the expense for those benefits (additional gloss, "boosting" a coating prior to installation), but i DO agree with the expense for the points i mentioned. there is nothing on the market like that, at least that i'm aware of. this is the first one.
different strokes, amirite?
Definitely. Didn't know that about Hyper either, thanks for the heads up.
Is this aggressive enough to remove OC 2.0?
There is a noticeable difference in gloss when using Essence, even after the paint is fully polished. I just finished up a car doing a full 2-step correction followed by Essence as a primer and the difference was impressive. I would say it added "richness" to the paint. I would much rather use this prior to coating than Eraser or IPA.
Just my $.02
Just my $.02
that's good info.
would you say the richness was similar to what happens when coated with CQF?
Chad, thanks for all of your input, how do you apply Essence with a Boss? Pad,speed....? I'm talking after a correction, and right before a coating.Thank you in advance.
that's good info.
I'd say it's similar, but I'll have to do a 50/50 and see if it darkens it at all like Finest does.
It's like the below pics, but not as extreme as this first pic wasn't fully finished yet.
Yes, I used the G21, Speed 4. I've tried it with a few different pads now but on the Audi above I used a yellow BOSS pad. I worked it longer on this car too as this was a repaint and Essence didn't like being short cycled for some reason. Once I worked it longer it was oh so nice!
I love it with a 12mm rupes. The pad marks you get on some paint completely stopped happening when I use the Duetto. Try it chad with gloss pad and it'll blind you.
I was never really impressed with the Duetto and NXT so I never bought one.
I was using it on the G15 with a gloss pad for a while but it had the same issue. Tried a few different things but once I worked it longer there was no more issues.
By Justin at Final Inspection in forum Show N' Shine
Last Post: 12-21-2015, 07:41 AM
By Jsmooth in forum Show N' Shine
Last Post: 06-30-2015, 07:46 PM
Last Post: 05-12-2015, 04:21 PM
Last Post: 05-11-2015, 10:32 PM
Last Post: 02-04-2015, 07:57 PM
