Megs Wheel brightener VS. Brown Royal
So lately I have seen a bunch of posts on Megs WB. I don't like to use it to much because I am scared it will hurt the rims. However, people had given me confidence about the product so I used it the other day.
Now, I have rims that are plasti-dipped and I don't like to touch the paint on them to much. I always used Iron-X and Sonax but they are expensive. I must say they do work well. With that said, I found Brown Royal a yr ago and had gotten some to try out. It is cheap and works great. Not as good at the Iron-X or Sonax but not far behind. After reading all the comments about the Megs WB I decided to try it out. I used a 4:1 and it sucked. I went back and resprayed it again then lightly agitated it and still it sucked. I ran to my Brown Royal and sprayed it on the rims and only rinsed them and they came clean. Am I not using the WB correctly or something? It has good reviews. I don't want to give up on it. I will have to do good review with all the products soon with pictures. Sorry, I didn't take any as I thought the WB was going to be the stuff.
In my opinion I like the Iron-X but don't use it as I save it for paint. Sonax I use more often because its for wheels. Brown Royal is the first one I reach for if its super cheap and works really well. I force myself to use the Megs WB and will keep forcing myself as it doesn't work for me.
I would highly suggest the Brown Royal to you guys if you have not tried it. Its not that expensive $30 or so and it smell like S#it, but so do the Iron-x and Sonax.
Re: Megs Wheel brightener VS. Brown Royal
It's possible it doesn not work well with plastidip. The only meg's product that I have used that works with plastidipped wheels is D143 Meguiars Non-Acid Wheel & Tire Cleaner.
You have mixed Megs WB correctley at 1:4 i have also seen the same results but what i am start to think is that brown royal and sonax are the same just one a little weaker and dont turn purple
Originally Posted by
jamesboyy
You are correct...besides the strength, color, consistency, color changing affects, country of origin, dilution ability, price....they are the same product. lol.
Hopefully you wore the proper HF-acid PPE when using WB.
stilltipping3
You are not using WB [D140] correctly.
Brown Royal is an alkaline (base) product...highly alkaline (highly basic).
One of WB D140 warnings is to avoid strong bases.
A harbinger of mixing an acid with a base.
Hopefully you also had some calcium carbonate on stand-by.
FUNX725
You are
This is one of the two reasons I don't like Megs WB. The other is it just doesn't work for me.
I ordered Meg's WB and should get it tomorrow.
Some mix it 50/50.
Is it effective at 4:1?
HateSwirls
Some mix it 50/50.
I don't like it bro. I think its not only very hazardous but there are better out there. U should seriously order the Brown Royal and I know u will be happy. All I can say is I am using WB wrong. If this is true, then it sucks because I used it on other wheels as well and the other products are far better. U will have to experience it and get back to me. Spend the money on some BR and then u will be happy. U can dilute that up to 10:1 as well. So for $30 its a 10gal product. THat stuff is FOR REAL.
Thanks man, wish I knew of this before I ordered it
I'll let you know soon.
stilltipping3
