Re: Megs microfiber cutting disc disappointent
Originally Posted by
takkychan381
I recently made my first $500 purchase from AG which included a pair of both 5 1/2 inch and 3 inch cutting discs to go along with my griots garage DA. I am very disappointed in the performance to say the least.
I started my process with the mf discs in conjunction with m105 to combat the swirls and minor scratches on my black 2009 chevrolet silverado. I checked my work after about 6 section passes with moderate pressure and found that there had been nearly zero correction of the scratches and a lot of the swirls still remained. I continued on to do another 6 section passes(Eeeek i know) on the same spot with the same results. This time most of the swirls had been removed but all of the scratches remained and so did 'some' swirls. I continued on to do the rest of my hood and both the driver and passenger front quarter panels. By the time i had finished those three panels, all four pads had exploded during use. Now i am stuff with a half compounded truck in my garage, with $500 in supplies and having to wait another week or so to order and recieve replacement pads (deffinitely foam)
I will post pictures as soon as i can, as i am mobile and it is difficult to do.
Also, in no way do i blame Autogeek. This is a great business. I am just extremely dissapointed in the megs mf discs.
I use them often and find them to be a gift from the heavens.
Last week a Toyota Tacoma, black, came to me with trashed paint.
Severe swirls and scratches.
Used my Flex3401, speed 3 with light pressure.
Once the MF Cutting Pad was prepped I applied 3 small dots to the pad.
I make 2 passes then clean it with my cleaning gun and make two more passes which seems to do the trick.
The fibers has to clean and not always matted down and why i clean it off after two passes.
Before I used the MF pad I used an orange cutting pad and did very little so I switched.
Sure cuts down on time which is important when running a detail shop.
Thanks for sharing and good luck
Sent from my SM-G965U using Autogeekonline mobile app
Hmm Kevin...I thought nobody liked MF pads on the Flex...I'm not sure if I ever tried it or not because everybody said I wouldn't like it.
