Pressure Washer Foam Cannon
So, I have an old Powermate 1100 I found after cleaning the basement and it's in real good shape. After all, just found it.
Anyway, what is the PSI I need to use with this foam cannon? Would 1100 PSI be ok?
Also, I don't know if any of the fittings that AG sells would work. I called the tech support for the powemate 1100 and they no longer support it.
If this doesn't work with the powemate, I'm thinking of the Karcher. What PSI should I get?
Thanks again folks!
Re: Pressure Washer Foam Cannon
I use a Greenworks with 1400 psi and the Foam Cannon works great.
Generally you need more than 1100 PSI to get a good thick foam. Something like 1500-1600 is recommended at minimum with a foam gun for best results
Thanks everyone. I can always use it for other projects or sell it at a garage sale.
Is there a mximun PSI? Mine is 3000psi
If you have a 3000psi unit and have not way to turn down the pressure you will want to be careful and not get to close or there is a chance you will do damage. Use a wide fan nozzle (40 degrees or better) or a adjustable nozzle.
Last Post: 04-12-2016, 11:01 AM
By bmwgeek in forum Auto Detailing Tools and Accessories
Last Post: 10-28-2011, 03:11 PM
By mcpp66 in forum Ask your detailing questions!
Last Post: 05-24-2010, 12:47 PM
By sullysdetailing in forum Auto Detailing Tools and Accessories
Last Post: 10-31-2009, 11:08 AM
By m4gician in forum Auto Detailing Tools and Accessories
Last Post: 11-12-2007, 04:52 PM
