Re: Meguiar's D/A Microfiber Correction System - 2004 F-150
Originally Posted by Mister B
Overall I really like these new liquids and microfiber pads. They are both easy to use and have long working times and wipe off is super easy for both with very little dusting.
Plus they both smell great, which is always nice when you are going to be working with a chemical for any length of time. The compound smelled like cinnamon and the finishing wax smelled like blueberries.
Great summary of your experience and the truck looks better than new!
Long buffing cycle
Easy wipe-off
Pleasant scents
All these things make any detailing project faster and easier and in the long run, more enjoyable.
Nice reflection shot...
sounds like next time I use the Finishing pad and wax on my car I might have to give a little more pressure..I had the same issue of showing marring after finishing wax and pad..i was bummed cause I really wanted it to work well with my car..so I guess I will give it a round 2 sometime down the road with a little more pressure.
Yes, I would definitely try the finishing wax again with more pressure. It worked great for me once I applied more pressure.
Can use menzerna FG500 on the cutting wool pads? and foam megs finish for wax?
Very nice finish there and thanks for the tips.
Excellent results and nice red F150.
I can't wait to order this system and use it next spring on my red F150. Based on your results, I think the kit will work really well on my truck and our other vehicles.
Good stuff. This is my #1 go-to pad and polish selection for almost every detail I do now. The last car I did for a customer I used the cutting pad with D300 and then finished off with the finishing pad and the D301. Next detail I do I am going to give M205 a test with the finishing pad so I can apply some BFWD as the LSP instead of the finishing wax.
I'd much rather spend an extra 20 minutes to apply a good sealant than leave someone with the AIO carnauba stuff in the D301 finishing wax.
By Meghan in forum How to Videos
Last Post: 06-06-2021, 12:00 AM
Last Post: 05-12-2020, 09:55 AM
Last Post: 12-17-2013, 11:48 PM
