Lake Country 1 Pad Polishing System
Keep in mind when reading this that I am a hobbyist detailer.
Product: Lake Country 1-Pad Polsihing System
Product Description : From Autogeek.net - With 1-Pad buffing pads, you use a fresh, new pad every time you detail. You don't spend valuable time cleaning pads. Every 1-Pad buffing pad performs perfectly. When your detail is finished, throw the pads away. Nothing is more valuable than your time. The time you save by tossing used pads offsets the cost of the 1-Pad Polishing System.
Would you buy this again or recommend it to a friend: Yes
Initial Product Observations: The pads seemed very thin. I was actually owrried that they may break down to early. The backing plate had a nice flexibilty to it though.
I used this system on my Flex LK603VVB. My first thoughts were that these pads seemed very thin. I was worried about pressure being applied to them and the backplate pushing on the paint. However, with the cushioning of the back plates tri density foam, my worries were for nothing.
Here is a pic of the back plate with a little pressure applied to it to show the tri density foam.
The orange pad seemed to be lense dense to the touch then a regular orange LC pad. I was not sure how this would play in to the cutting ability.
Here are the pics of the orange pad and the a regular LC orange pad.
1Pad
LC Pad
The white pads seemed very similar in feel and texture to a regular pad. Sorry I did not have a new white pad to put a compare picture up with.
The grey pad was like the white in the fact that it felt very similar in composition to the regular black pad.
I liked the way the pads were curved and allowed me to move over the body work.
While working with these pads I noticed that were very easy to control and held up very well. It has very little velcro on the bac of the pad, and I was worried that the pad might slip. After I was done using them on my car, I ran the pad at a higher RPM and applied quite a bit of pressure to it on some plexiglass. I marked the pad and the backplate with Sharpie to see if it moved at all. It did not.
The cut of the pads seemed to be on par with regular pads, and I was able to finish the car nicely with th white pad and some Optimum Hyper Polish.
I have the pads soaking, and will be cleaning them. I know, this defeats the purpose of the 1 time use pad right? Not in my opinion. I am cleaning them to see how well they held up, in case anyone is worried about not being able to finish a car with one pad.
Pros: No cleaning, good cut, curved sruface makes it easy on edges and contours.
Cons: Could get expensive.
Final Observations and Summary: Since I have this sytem now, I will continue to use it. It worked great for me. I will only be using the orange and white pads though, as when I get in to the grey pads I like to move on to my PC. I am also considering the Cyan and Yellow to be my next purchase.
Re: Lake Country 1 Pad Polishing System
fantastic review.,
my goodness, that pic of the curved pad makes me crave a similar pad for a DA or Random Orbital.
is there anway this could work on a DA ?
edit: upon another look at the pic, it seems the orbital throw of a DA would defeat the purpose of a smooth curved edge, as it would be jiggling back and forth on a curve like that.
Thank You for the post (pictures).
I ordered the 1-Pad system (BP+3 pads) for correcting the contours of my TA so I can put on a coat of CQ or OC.My RamAir(WS6) hood has a few pronounced curves that I feel these pads will work great for.
Depending how they work on my TA,I may use them for customers that have vehicle profile's that these new 1-Pad would meet them needs.Which would be the only reason IMO to order them.
Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
No problem guys. I am honored that I got the opprotunity to do it.
IID, I LOVE the WS6! One of my favorite cars. Soo sexy. This pad did work great for the contours on my hood. The pics that I took are just before I started the hood, so the compound is not on the edge of the pad yet.
This picture shows the contour of my hood. While not as drastic as a WS6, it is still pretty contoured.
Indeed it is.
I'm glad you liked the 1-Pad system.I should get mine tomorrow.
BTW,Beautiful snake!
Thanks man. Let us know what you think of the kit.
Thanks for sharing. Keep us posted as you continue to evaluate the system.
Ron !!!!!
I am going to give these a try again on another car on Saturday just to see how long they truly last and cut. While this does not matter on a single use pad, I am doing for my own curiosity.
By Sizzle Chest in forum Product Reviews
Last Post: 10-11-2016, 11:42 AM
Last Post: 01-18-2011, 04:21 PM
By Mike Phillips in forum New Car Care Products
Last Post: 01-14-2011, 05:04 PM
Last Post: 01-07-2011, 11:41 PM
By tuscarora dave in forum Auto Detailing 101
Last Post: 12-28-2010, 07:26 PM
