Results 1 to 6 of 6
    Apr 2021
    NJ
    Griot's G8 Polisher
    I am new hobbyist and purchased a Griot's G9 and a G8. I use the G9 with mostly 5" pads from LC and Boss with minimum stalling and great results. However, the G8 using same type of pads 3" seems to stall all the time. Whenever I use it on concave, non flat surfaces or angled with very light pressure it just does not oscillate. Even on some smaller regular surfaces if it is not held exactly at the right angle it won't rotate. Frustrating because I have nothing to compare it to but the G9 and not sure if I'm expecting too much. How sensitive is this polisher? I am finding the same issues from using Fast correcting at speed 5.5 to polishing at 3.5. Anyone with experience on this? Or any tips? I have an email into Griot's but they haven't responded yet.
    Thanks.
    2011 Black F350
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    Re: Griot's G8 Polisher
    Crank it up and see if that helps. Sometimes the number doesn't correspond with the actual speed.
    Apr 2021
    NJ
    Thanks just tried that last night using boss MF fast cutting pads on a white Audi. Kept it on 6 (full speed) the entire time and it didn't help. Seems like it is very sensitive to being perfectly perpendicular to even the flat panels. I think I'll talk to Griot's on this one. Thanks for your help.
    2011 Black F350
    SELF BANNED
    Jun 2019
    1,076
    It took me a number of hours to get use to the G8. Concentrate on your back hand to make sure the pad is flat and i use less downward pressure on the top of the G8 compared to my first gen. G15 - I also run my G8 on speed 5 most of the time.
    It does stall easier then the G15. Maybe its because the slightest outset of pressure effects a small pad/machine more then a larger one. I have to use more finesse with the G8 then the G15 but its a capable little machine IME. Body positioning also makes a big difference, get comfortable and close to the machine with your eyes so to speak.
    Mar 2017
    Southeastern PA
    2,480
    MF pads are more grabby and will help the tool stall more often if not flat on the surface. Increase tool speed and lighten up the pressure but other than that, just can’t do much other than using forced rotation or a smaller tool/pad to not be inside the concave area so much.
    Bruno Soares
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    Questions to OP...
    Are you finding the stalling happened more on the vertical passes or the horizontal passes ?
    How big was your working area when using the G8?
  1. Griot's BOSS G10 Pneumatic Polisher - Air powered 10mm dual action polisher!
    Last Post: 04-08-2018, 09:52 PM
  2. Replies: 0
    Last Post: 09-25-2017, 04:47 AM
  3. Should I buy a Griot's DA Polisher?
    Last Post: 05-10-2015, 10:15 PM
  4. 3" Mini Polisher- Gen II - Griot's Garage Mini Polisher
    Last Post: 12-15-2013, 08:05 PM
  5. Griot's Garage Random Orbital 3' Polisher as primary polisher
    By torque1989 in forum Ask your detailing questions!
    Last Post: 07-01-2011, 10:11 AM
