Results 11 to 20 of 29
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Re: Griot's Garage Foam Cannon v2 experiences
    Interesting. I will use the Griots Foam wash soon and take some pics to see how it looks with my set up.
  2. Thanks irvsmith thanked for this post
  3. #12
    Super Member irvsmith's Avatar
    Nov 2014
    611
    It was quite an improvement in my book from what I was experiencing with the GG foam cannon 2.
  4. #13
    Nov 2014
    611
    As a follow up - Here is the GG surface wash with the replacement GG foam cannon, 1.1mm orifice, auto mixing function with purple tip. After foaming and after a few minutes dwell. In person the initial foaming was thicker than it appears in the images.
  5. Likes PaulMys, SWETM liked this post
  6. #14
    Dec 2018
    7,169
    Quote Originally Posted by irvsmith View Post
    Just a follow up - I sent the GG for exchange and hope the replacement works better. I received my PF22 and used it for the first time this afternoon. Here are some photos of the results.
    What soap is this?
  7. #15
    Super Member bob m's Avatar
    May 2009
    Glen Ridge, NJ
    294
    What soap is this?
  8. Likes Coatingsarecrack liked this post
  9. #16
    Dec 2018
    7,169
    I tried surface prep with PBMG foam booster I got as a sample and it gave it a good amount more thickness.
    Used it with pf22 and ryobi 2300 psi 1.2 gpm pressure washer. Might
  10. #17
    Sep 2013
    SF Bay Area, Cali
    2,939
    Here is my most recent experience using GG Surface Wash in my PF22 and my little Greenworks PW. 2oz of soap.
  11. Likes SWETM liked this post
  12. #18
    Dec 2018
    7,169
    That’s about what I get with no foam booster with my 1.2 gpm ryobi. Does a good job
  13. #19
    Sep 2017
    Sweden
    3,022
    I like how the Surface Wash seems to cling on great. Do you guys see the run off part from the foam too on the ground? As I understand it it's a 2 part foam that 1 layer run off easier and the 2 part leaves a thinner wet foam left. This is useally very effective to have on for a long dwell time without it to dry on the paint. It's also useally makes a big difference in the cleaning ability when you have it to dwell as long as possible on dirtier vehicals.
  14. #20
    Super Member Belo's Avatar
    Jul 2014
    Rochester, NY
    492
    i have a power washer but didn't when i bought my foam gun years ago. the results are adequate just using megs gold class. What's the advantage of using a pressure washer to apply foaming soap, given that you're really just looking to cover the car with foam, and can someone convince me that it's worth the gas, setup and cleanup to use my pressure washer and spend the $100 on the cannon?
    hobbyist only here
    2009 Pontiac G8GT
    2015 Ford Explorer Limited
    2019 Chevy Silverado RST Z71
  1. Replies: 3
    Last Post: 01-23-2021, 09:48 AM
  2. AutoGeek foam cannon vs MTM foam cannon
    By Speedie6 in forum Auto Detailing 101
    Last Post: 03-23-2018, 08:14 AM
  3. Replies: 17
    Last Post: 05-30-2016, 02:44 AM
  4. Gilmour Foammaster II or Griot's Garage Foam Gun?
    By Matt@Revive in forum Product Reviews
    Last Post: 01-22-2015, 08:26 PM
  5. Question: Griot's Garage MicroFiber and Foam Pad Cleaner
    By szjalo in forum Auto Detailing 101
    Last Post: 04-28-2014, 12:45 AM
