Is this product safe to use on plastic chrome trim pieces?
The problem with plastic chrome pieces is they vary from manufacturer to manufacturer. Some are more brittle and sensitive and you can easily damage the more sensitive ones. Others are alot more durable. But if you did want to clean some up, Test a very tiny spot to see how the plastic reacts. To be on the safe side as always. If your test spot appears that it came out ok. Apply lightly just to brighten and enhance the surface. When I get into situations like this I always ask my self as a professional is the Risk worth the reward. I can explain dull plastic trim to the customer alot easier than damaged plastic trim. Just be careful, As I said above every manufacturer use different materials.
