Re: Rupes 5 Inch 2000 & 3000 Grit Sanding Discs
Quote:
Originally Posted by
Andr3wilson
Although the one element I need to ask, how does it feel compared to a palm style sander? More down to user preference I guess,
but how did you find it to the comparable RUPES palm sander?
In our garage we have the 3M Orbital Air Sander, the Rupes Orbital Air Sander and my personal orbital air sander I brought with my from California my Dynabrade.
Here's the skinny...
All thread work great and the ergonomics of holding, using and sanding with a palm sander is much better and easier as well as safer than machine sanding with an electric polisher mostly used for paint polishing.
The big picture however is most people don't' own an air compressor with a large enough reserve tank capacity, let alone the air compressing power to maintain the tank capacity to use an air powered air sander.
Here's ours...
Ingersoll Rand Rotary Screw Compressor
http://www.autogeekonline.net/galler...mStudio003.jpg
But yeah... I like to sand with them. I don't like the stiff air line that goes with using an air powered DA sander.
Also, if any reps for any companies that sell air powered DA sanders are ever reading this into the future, please make it so the throttle is not a slide switch but use some type of ratchet steps in-between speed settings as these things are just way to easy to bump and adjust when your sanding.
You can see the Throttle next to my thumb on the underside of this 3M Air-Powered DA Sander
http://www.autogeekonline.net/galler...pSanding02.jpg
Out of the three above air sanders I found the 3M and the Rupes to work faster than my Dynabrade but my Dynabrade is a "finishing" sander, it has a smaller orbit stroke length.
3M Random Orbital 6 Inch Air Sander 20325
http://www.autogeekonline.net/galler...pSanding01.jpg
http://www.autogeekonline.net/galler...Sander_001.jpg
Machine sanding a 1970 Oldsmobile Cutlass with the Rupes Air Sander
http://www.autogeekonline.net/galler...e_Peel_008.jpg
This is me using my Dynabrade when I wetsanded the Joker Truck
http://www.showcargarage.com/gallery...OnJoker006.jpg
Can X Cut foam pads (150 mm) can be used with lower stroke DA Machine than 12 Duetto as I do not have that one.
From Rupes I have LHR 15 Mark II so I was planing to use X Cut Foam pads with Meguiars MT310 which is 8 mm stroke.
Also what machine speed is reccomended for these pads.
Thx
ARTB155
First, do you mean the
RUPES X-Cut Foam Sanding Discs
I just need to clarify because you wrote
X Cut foam pads
Without the word RUPES in the front and using the word pads instead of discs, I don't like to assume what you mean.
But if you do in fact mean,
Then the answer is YES you can use these foam backed machine sanding discs from RUPES with 8mm Orbital Polishers like the Griot's Garage 6" DA, the Meguiar's MT300 DA and the Porter Cable 7424XP DA.
ARTB155
Yes you can use the Meguiar's MT300 to machine sand. Because of the long body it will be a little more awkward and cumbersome to sand with but it will work.
ARTB155
Also what machine speed is recommended for these pads.
Thx
You need to maintain pad rotation.
So mark your backing plate so your eyes can see pad rotation and then adjust the speed dial as needed to maintain pad rotation.
Just add....
I wrote the below article when shortly after Meguiar's introduced their Unigrit discs back in the fall of 2009. My article came out in May of 2010. It's actually the only article I've ever seen on the topic of damp sanding and it is more than in-depth... it's exhaustive.
All the tips and techniques I shared in this how-to article are just as accurate today as when it was written. All the tips and techniques shared in this article appley to ANY brand of sanding disc that is made to be used with water.
Damp-Sanding Tools, Tips and Techniques by Mike Phillips
Just out of curiosity....
What are you working on?
Mike
Thank you for your reply.
Yes, I mean about Rupes X Cut Sanding Discs not pads (typing error) so you were in right direction.
I am working on a VW Golf 2005. hood as there are lots of scratches causes by the owner when he try to remove some spillage with scotch brite side of dishes sponge together with some dishes abrasive liquid (in my country it is called Arf and it is very abrasive and used for inox dishes washing).
As there is a lot of clear coat (hood was repainted by previous owner) I had plenty of "space" for sanding.
Thx
ARTB155
Mike
Check.
ARTB155
Thx
Good to hear... more paint is better when it comes to sanding....
Btw. few days ago I received your book about Rupes Polishing System and it is great - probably first in my country Croatia :-)...
Now looking for your other books to add to my collection.
ARTB155
Thank you!
It takes a lot of thinking work to write a book. It's real easy for everyone to post their opinion on a car detailing topic... try compiling an entire book filled with your opinion and then putting it out on the market for peer review worldwide.
Perhaps consider writing a short testimony and send it to Nick for the Autogeek store. Testimonies help others to decide whether or not to go for it.
Nick@Autogeek.net
Done...Nick will soon recive my email...so lets back on topic :-)..
