Results 11 to 20 of 25
    Re: Review: DP GR4 Graphene Coating
    Quote Originally Posted by chavez885 View Post
    Looking good boss, I'll have to pick some up.
    Thank you.
    The paint on this car really did look as good and even better as you see in the pictures. And I used my iPhone to take the pictures.
    May 2017
    Pittsburgh PA
    2,847
    Mike,
    In your review you mentioned to the owner not to use car washes (even touch-less, I interpret).
    “How long will it last? I don't know, that's the problem with this type of product review. The car I used this on is gone. I have asked the owner to AVOID taking the car through touchless car washes. While in theory it sounds like a good option for those times you can't do a normal water hose and bucket wash in your driveway. But the down side is - these types of car washes tend to use stronger chemicals to loosen road film and dirt since NOTHING is going to physically touch the paint to clean it.
    While these harsher chemicals may not remove the coating - I "think" they are responsible for making the anodized aluminum trim surrounding the windows look horrible, spotted and splotchy...
    ...I coated the trim, but this type of anodized aluminum trim is sensitive to chemical corrosion - thus the reason I've asked the owners to not take this car through any touchless car washes.”
    I agree with the advice as a general practice. But am also curious as to whether the advice is only due to the anodized trim, or are you also concerned about the chemical resistance of this coating? Will touchless washes wear on this coating more so than other big name coatings (which I would expect are barely/not weakened by occasional touch-less washes)?
    Just wondering if you have any inside info that would make avoiding automatic washes a higher priority for this Graphene coating in particular.
    Thanks in advance!
  3. #13
    Aug 2020
    890
    Mike, did you coat the anodized trim or let it bare?
  4. #14
    Quote Originally Posted by DUBL0WS6 View Post
    I machine polished it and then I coated it.
  5. Likes Anna Louise liked this post
  6. #15
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,709
    I applied this to a small section as part of my coating test. I have to say that it is on the slick side. For those that are looking for a coating that offers some slickness instead of the typical tacky coating sensation then this is it. For those that have used Gtechniq Chrystal Serum Light, Cquartz SiC or the previous Cquartz TiO2, GR4 is a tad behind in the slickness aspect.
    Application is easy. Slight rainbowing.
  7. Thanks oneheadlite thanked for this post
  8. #16
    Junior Member jshillin's Avatar
    Jun 2007
    Waynesboro, PA
    38
    I finally got around to cleaning my truck 2 weekends back. It was 3 years since I last polished/coated it with CQuartz and it was due for some new protection. The paint wasn't in bad shape because I really try to keep up with it, so I didn't need much. I washed with foam canon, hit it with IronX, Nanonskin fine sponge, hit it with Gyeon Polish on my CBeast with a white pad. Followed up with a good IPA wipedown and applied the GR4. It goes on different than other coatings I've used before, seemed almost like a sealant type feel than a coating. It is definitely slick when finished and really shines.
    Review: DP GR4 Graphene Coating-ram_front_corner-jpg
    Review: DP GR4 Graphene Coating-rear_corner-jpg
    Review: DP GR4 Graphene Coating-ram_side-jpg
  9. Likes dwaleke liked this post
  10. #17
    Quote Originally Posted by jshillin View Post
    That's the primary reason I like it, the slick feel.
    Nice looking truck!
    Is that a factory color?
  11. #18
    Mike,
    My advice had to do with the anodized trim.
    No, not that I'm aware of.
    Thanks in advance!
    No other insight except that anodized aluminum trim is really difficult to fix once it becomes stained. So for most people, if you have a car that has anodized trim, my advice is to avoid touchless car washes and also iron remover.
    Good questions, thank you for asking.
  12. #19
    Jun 2007
    Waynesboro, PA
    38
    Nice looking truck!
    Thanks Mike. Yep, factory Paint, True Blue Pearlcoat! It shines real nice and looks like a mirror to see my other favorite blue in the background, WRB
    Attached Thumbnails Attached Thumbnails Review: DP GR4 Graphene Coating-ram_wrx-jpg
  13. Likes Anna Louise liked this post
  14. #20
    Sep 2009
    Can you develop high spots with coating similar to what can happen with a ceramic coating. If it does develop a high spot do you have to polish the sot to remove it?
  1. Review: 303 Graphene Nano Spray Coating
    Last Post: 05-27-2023, 09:48 AM
  2. Recommendation: Microfiber Applicator Pad for applying 303 Graphene Nano Coating Spray
    Last Post: 06-28-2021, 09:13 AM
  3. Which Ceramic/Graphene coating to use on a new Pacifica?
    By kmical in forum Auto Detailing 101
    Last Post: 03-16-2021, 04:41 AM
  4. Onyx ceramic and graphene coating
    By wakeel in forum Auto Detailing 101
    Last Post: 03-13-2021, 09:42 PM
  5. How long does a Graphene coating stay slick?
    By spazzz in forum Auto Detailing 101
    Last Post: 09-29-2020, 09:06 AM
» December 2023
2627282930 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
