» Detailing Classes
Page 10 of 10 FirstFirst 12345678910
Results 91 to 99 of 99
  1. #91
    Senior Member Craig Encinitas's Avatar
    Jul 2020
    175
    Now available - Dr. Beasley's Z1 Ceramic AIO Primer
    Quote Originally Posted by TMQ View Post
    Buffing issues...
    Tom Iím basically tagging you in this post. I am using the NSP line before I coat it this morning with Nano Resin.
    The buff- is a bear! The surface is not slick at all after I buff it off. I know Toyota paint can be soft, and itís a fine line between getting the polish off and scratching the paint with a microfiber.
    Just sharing my thoughts here. I have no idea why itís not slick. All the other primer polishes Iíve used from other companies have always felt very slick afterwards. And I tested these out on a couple other vehicles before using them. Maybe itís just the Toyota paint? It is definitely glossier.
    I am using the FLEX XCE & FCE with light polish pad and also the LC red finess to finish it up. No matter what combo I use, even going heavy in product...or going light on it...doing a couple quick light passes...damp MF before a dry one...same deal...difficult to wipe off.
  2. #92
    Senior Member TMQ's Avatar
    Mar 2015
    Germantown, Md
    1,935
    Re: Now available - Dr. Beasley's Z1 Ceramic AIO Primer
    Thanks....
    I thought I was the issue. You just confirmed that I'm ok! Grin...
    When I did the Shelby just like yours---Had a hard time getting it off. It has never had anything on paint since leaving the factory.
    It was like paint was thirsty and was clinging onto the product. And I was more tired using this AIO than I ever been.
    Just did that big F150 pickup couple weeks ago---
    It has the Opti-pro +. A seven year coating. When I did the work, it was already 4 years old. Still has 3 more years left. Was very contaminated! Felt like 80 grit on the surface.
    Did a buzz cut with the Z1. Wasn't too bad wiping off. The Opti pro base made it easy to pull off. BUT even then with solid ceramic base, some spots needed couple more passes to remove wet haze from product. Under the lights paint was perfect!
    I was good!
    Customer came to pick up the truck, he was very happy how it turned out.
    As customer pulled out into the twilight light----High spots!!! All over the upper part of rear bed and rear cabin corners!
    Muttered some inappropriate words to post here!
    Took a towel to rub down the hight spots---nope. Broke out the pixie and redone those areas. Was able get 90% off.
    Geez, And this customer is really picky about how surfaces look! Few more words here...!
    Thankfully I told the customer up front that I was trying some really new stuff and we may run into some issues. He was good with that!
    So in your case re the Tundra, if surface is not smooth or if it doesn't have anything previous protection on it or if it feels or looks dry, it's going to stick!
    Thanks for letting me know, Craig.
    Tom
    Mr Tommy's
    Wash, Buff, Wax
    Website: mrtommyshine.com
  3. Thanks Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  4. #93
    Mar 2015
    Germantown, Md
    1,935
    Hope Jim gets a chance to read this!
    This IS a game changer and once it becomes easy to wipe off---It WILL be the game changer!
    Tom
    Mr Tommy's
    Wash, Buff, Wax
  5. #94
    Mar 2015
    Germantown, Md
    1,935
    Re-read your post.
    What NSP polish you used? #45?
    And It's not the Toyota paint. Bet if you used your TAC primers, you probably would have had a different result.
    When I run into something like what you just went through, I tend to stop and pull out my trusty Rupes polish to see what happens. And compare results between the 2 polishes.
    Tom
    Mr Tommy's
    Wash, Buff, Wax
  6. Thanks Craig Encinitas thanked for this post
  7. #95
    Jul 2020
    175
    This is a 2018 Tundra, with around 20,000 miles. The owner purchased it used and I got as much history on it as I could. I finished the polish process with 45, but there were some deeper scratches so I used the higher cut ones prior.
    The Nano Resin is going on nicely now, and it feels slicker. Thanks for your help Tom
  8. Likes TMQ liked this post
  9. #96
    Junior Member JT Moto's Avatar
    Sep 2020
    I used Z1 for the first time Friday and found it very easy to wipe off. I followed the Doctors directions and has a very nice wipe off. I ran out of time so I only did the front half of a little Chevy Bolt but I was impressed with the product.
  10. Thanks Craig Encinitas thanked for this post
  11. #97
    Jul 2020
    175
    I did everything but switch to a different brand of polish to try and get an easier wipe off. Thereís a few cars around here I can practice on and see whatís going on.
    Thanks.
  12. Likes TMQ liked this post
  13. #98
    Mar 2018
    Conroe, Texas
    422
    I used Z1 this past week and used less product each time after my first loading of the pad. I found it easy to remove with a short nap MF towel.
    I did most of the car with NSP 45 but then on the roof wanted to try the Z1 for being a one step. I was expecting to run out of my ceramic coating product.
    I will state that you will not get a perfect wipe-off in comparison to other polishing products. You will find it a bit grabby if too heavily applied and then even some light passes can result the same on the NSP. These products (IMHO) are intended to NOT wipe off cleanly like my Griot's products nor Sonax polishes. They are designed to leave behind a bonding agent as in the NSP line or in the Z1 leave behind a ceramic sealant. And if you want to apply then any brand of coatings this layer will improve the bonding of the top layer to the clear coat below. So far it has lived up to those expectations.
    Hope you the same as you work and learn the product.
    My final photo showing roof after applying a NonAG product
  14. Thanks Craig Encinitas thanked for this post
  15. #99
    Senior Member briarpatch's Avatar
    Sep 2015
    1,457
    And it's these inconsistencies in the wipe off that is keeping me from pulling the trigger on it. I'd like nothing better than a one-step that would give a year of protection, but not gonna buy it until they get the bugs out.
  16. Thanks Craig Encinitas thanked for this post
    Likes john b liked this post
  1. Gyeon Q2 Primer
    By noorth in forum GYEON Car Care Products
    Last Post: 11-24-2020, 09:33 AM
  2. Replies: 40
    Last Post: 09-26-2020, 04:57 AM
  3. blackfire primer
    By john b in forum Hot topics & Frequently Asked Questions
    Last Post: 12-25-2018, 07:46 PM
  4. IPA primer before wax ?
    By Charlieboy1 in forum Auto Detailing 101
    Last Post: 07-17-2018, 07:40 PM
  5. Essensse as a primer
    By parshisa in forum Auto Detailing 101
    Last Post: 02-26-2018, 04:51 AM
Members who have read this thread: 135
» December 2020
2930 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
